Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
Replaced TPS and still having issues....
Old Jun 26, 2008 | 03:09 PM
dme44's Avatar
dme44
Default Replaced TPS and still having issues....
Good Day,
My 1990 Dakota LE 3.9 V6 is having symptoms of a bad TPS, but I already replaced it twice. The strange thing about this whole situation is the truck runs fine around town, but as soon as I get it up to highway speeds for 10 miles or so - the hesitation and stalling occurs.
To confuse things even more - if I disconnect the battery overnight the truck will once again run fine for a little while or until another run on the highway.
I am at a loss to what could be causing the problems and no one around here can seem to help.
Any ideas or thoughts would be greatly appreciated.
Thanks,
Dave
Old Jul 15, 2008 | 02:39 PM
JetNoise's Avatar
JetNoise
Default RE: Replaced TPS and still having issues....
do you have a check engine light?
What are all of the symptoms that you are having?
I figure that the reason why it works well after a battery disconnect is that your computer "forgets" things.
Old Jul 19, 2008 | 01:57 PM
dme44's Avatar
dme44
I did the on-off-on-off-on and got two codes.
12 - battery disconnect ( I knew this one was going to show)
and
31 - EVAP Solenoid
Not sure if this would cause the stalling issue and I am kind of surprised I got this as I just had an inspection and emissions test and it passed with flying colors.
I am going to inspect the system myself today to see if I can find any cracks or leaks.
Thanks!
