Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
What is causing this?
Old Feb 3, 2004 | 11:58 AM
dakrt_00's Avatar
dakrt_00
Default What is causing this?
Does anyone have a problem with your truck not being able to shift out of first. Ihave a 2000 R/T and when I stomp on it from a stand still the rpm's shoot up and wont shift to second when it needs to. It will just start cutting the truck off because of being in the red line and finally shift when you let off the gas. This really sucks when you try to race someone. </P>
Does anyone know what might cause this and maybe how to fix it?</P>
Old Feb 3, 2004 | 05:05 PM
DodgeIT's Avatar
DodgeIT
Sounds like a speed sensor.
Old Feb 3, 2004 | 05:39 PM
Vader's Avatar
Vader
Check vacuum lines also. Make sure all are properly connected.
Old Feb 9, 2004 | 05:49 AM
vHiEpMeIr's Avatar
vHiEpMeIr
Default RE: What is causing this?
You might need your transmission fluid changed, when was the last time you had that done? My Mustang won't go into 3rd gear so we are going to have the transmission fluid changed and they said hopefully that's the problem. Either that or there might be some gunk in the linkage, does it have trouble dropping into gears like Drive or Reverse? Not while driving, like when you are sitting and put it in reverse does it get stuck?
Old Feb 9, 2004 | 01:11 PM
dakrt_00's Avatar
dakrt_00
No, the problem only occurs when you start out. It only does it when you stomp on the gas and take off. It goes completely to the rpm red lines and starts cutting the truck off because of being in the red line. Then when you let off the gas just a little it's fine, which sucks because you don't want to have to slow down. Thats the only problem there is. I hadn't made it to the dealership yet but hopefully I can soon.
Old Feb 9, 2004 | 03:20 PM
RcBandit28's Avatar
RcBandit28
Did it throw a check engine light or anything?
Old Feb 11, 2004 | 12:57 PM
dakrt_00's Avatar
dakrt_00
IT DOESN'T CAUSE ANY LIGHTS TO COME ON AND IT HAS DONE IT MORE THAN ONCE TOO.
Old Apr 4, 2004 | 11:58 PM
kccapn's Avatar
kccapn
I had this same problem. I talked to a local transmission shop and they recommended resettting the pcm. There are a couple of places on the internet that wil tell you to remove the negative battery cable and turn the key to the start position and hold it for 15 seconds. This did not work for mine. After talking with the guys at Superchips about it, they told me to remove both of the battery cables and tape them together for abuot 3 minutes,... (none of this should ever touch either post on the battery. That could cause a major pcm problem) I qusetioned their theory on this, and the guy at Superchips said that it is the equivalent of rebooting your home computer. After some skepticism on my part, I finally tried it. It worked, and has never done it again.
Old Apr 5, 2004 | 12:13 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
The more computers they have, the stranger the solutions....
Old Apr 5, 2004 | 12:47 PM
dakrt_00's Avatar
dakrt_00
I will have to try this, thanks for the suggestions.
