Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
Need some help!
Old May 21, 2009 | 11:12 AM
Stupid Move's Avatar
Stupid Move
Default Need some help!
I have an '09 Dakota and thought it was a good idea to cut the wire underneath the driver's seat to disable the seat belt chime. My stupid move back fired big time. The car thinks the seat belt is undone at all times now. The alarm won't shut off. I've now read through some posts and found a way to disable it manually by playing with the buckle a few times when you start it. Obviously that won't work for me after I cut the wire.
Is there anything I can do without having to have the line repaired??? Any chance there is a fuse that only works the seat belt alarm that I could unplug?
Old Jun 1, 2009 | 01:24 AM
Crazy4x4RT's Avatar
Crazy4x4RT
You may want to post this question under the 3rd Gen. Dakota section.
Old Jun 1, 2009 | 12:00 PM
Billiam's Avatar
Billiam
And Im sure the better way would have been to check to see if there is a fuse you could have pulled.. lol Hopefully you get her fixed.
Old Jun 1, 2009 | 05:59 PM
Beazer's Avatar
Beazer
Or simply splice the wire back together. If the ends are too short, you can just buy the same gauge wire and put a patch in between the two ends splicing at both ends of the patch.
