Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
engine codes P0508 and P0509
Old Sep 13, 2006 | 12:17 AM
machuca06's Avatar
machuca06
Default engine codes P0508 and P0509
Can someone please help me? I have a Dakota 2004 V8 4.7 engine. my engine light came on today and my truck stop idling. I look at my engine codes and it gave me P0508 and P0509. Can someone tell what this mean and how I can fix it? I look everywhere but could not find those codes. please help!!!
Old Sep 13, 2006 | 01:42 AM
Daksport1pa's Avatar
Daksport1pa
Default RE: engine codes P0508 and P0509
I think this will help you out sir. https://dodgeforum.com/m_555666/tm.htm
Hmmm. I decided to look at the list myself to see what you codes were and they are not on the list. I may have to do a lil more research into this one.
Old Sep 13, 2006 | 05:43 AM
dodgerules86's Avatar
dodgerules86
Well, P0508-IDLE AIR CONTROL VALVE SENSE CIRCUIT LOW, P0509-IDLE AIR CONTROL VALVE SENSE CIRCUIT HIGH.
The "possible causes" are:
P0508
IAC CONTROL CIRCUIT SHORTED TO GROUND
IAC SIGNAL CIRCUIT OPEN
IAC SIGNAL CIRCUIT SHORTED TO GROUND
IAC CONTROL CIRCUIT OPEN
IAC MOTOR
PCM
and P0509
IAC RETURN CIRCUIT SHORTED TO BATTERY VOLTAGE
IAC CONTROL CIRCUIT SHORTED TO BATTERY VOLTAGE
IAC CONTROL CIRCUIT SHORTED TO THE (K961) IAC RETURN CIRCUIT
IAC MOTOR
PCM
We have search results!!
Clicky here.
I would bet your IAC motor is shot. This is located on your throttle body. Look at #3 in the picture.
[IMG]local://upfiles/948/011607FF56AA4D5190716F175295BFB6.jpg[/IMG]
Old Sep 13, 2006 | 08:08 PM
Daksport1pa
ORIGINAL: dodgerules86
P0508
IAC MOTOR
PCM
and P0509
IAC MOTOR
PCM
Clicky here.
Nice. I"m going to add those to the list.
