Dodge Dart The Dodge Dart forum is the place for all Dart 2013+ Owners Discussion
Reset oil change warning?
Old Nov 26, 2013 | 08:31 PM
Spillage's Avatar
Spillage
Default Reset oil change warning?
Can the oil change warning be reset with a scan tool?
Or is it dealer only?
Old Nov 27, 2013 | 03:44 PM
DodgeCACares's Avatar
DodgeCACares
Spillage,
To reset the oil change indicator system (after performing the scheduled maintenance) for,
Vehicles Equipped with Keyless Enter-N-Go:
1. Without pressing the brake pedal, press the ENGINE START/STOP button and cycle the ignition to the ON/RUN position (Do not start the engine)
2. Fully depress the accelerator pedal, slowly, 3 times within 10 seconds.
3. Without pressing the brake pedal, press the ENGINE START/STOP button once to return the ignition to the OFF/LOCK position.
Vehicles Not Equipped with Keyless Enter-N-Go:
1. Turn the ignition switch to the ON/RUN position (Do not start the engine).
3. Turn the ignition switch to the OFF/LOCK position.
Please note; if the indicator message illuminates when you start the vehicle, the oil change indicator system did not reset. If necessary, repeat this procedure.
This information can be found starting on page 303 of the Owner's Manual. If you have any questions please feel free to PM me.
Old Nov 28, 2013 | 09:16 AM
Spillage's Avatar
Spillage
Thank you Katie... your time in responding is appreciated.
Old Nov 29, 2013 | 08:46 AM
DodgeCACares
Spillage,
No problem, I hope this helps.
