Dodge Daytona The G platform cars that are to this day, fun sporty machines that car modding enthusiasts love to get their hands on, the Dodge Daytona and Chrysler Laser.
Looking for answers
Old Apr 11, 2007 | 06:45 PM
88 shelby girl's Avatar
88 shelby girl
Default Looking for answers
I just recently rebuilt my engine and tranny for my Shelby and it has solved most of the problems I was having with it except for the most anoying one: on some days when I start it it will start fine but stall. If I keep on the throttle it will go and after awhile it runs just fine. I have taken it to several mechanics as well as done what my manual suggested but nothing helps! Does anyone have an idea what it could be?!? Also does anyone know where I can find a diagram for the vaccum lines for my year and model? ANY SUGGESTIONS ARE MUCH APPRECIATED
Old Apr 14, 2007 | 05:15 PM
88 shelby girl
Default RE: Looking for answers
Okay any suggestion anyone? I'm open to any suggestions
Old Apr 14, 2007 | 07:08 PM
89Daytona's Avatar
89Daytona
List the things you have replaced already.
Possibilities include sparkplugs, sparkplug wires, coolant temp sensor, and check codes.
There should be a vacuum hose diagram on the underside of the hood.
They are also available on the Autozone website in the repair info section. http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Here are some of the diagrams:
Vacuum hose routing-1988 2.2L and 2.5L Canadian, Federal and Altitude EFI engines
Vacuum hose routing-1988 2.2L and 2.5L California EFI engines
Vacuum hose routing-1988 2.2L Turbo 1 engine
Vacuum hose routing-1988-89 2.2L Turbo II engine
Vacuum hose routing-1988 2.2L Turbo III engine
Old Apr 14, 2007 | 07:20 PM
88 shelby girl
I replaced everything except the temp sensor so i'll try that. There arent any codes and I would use the diagram under the hood but I am actually looking for the original hood because it was replaced with a different hood. I guess there was damage to it and they couldn't find one so they just put one that was close to it
Old Apr 24, 2007 | 01:00 AM
shelbydaytona91's Avatar
shelbydaytona91
This is going to sound stupid but did you check the oil level or have you changed the oil recently? That was happening to my friend's Grand Marquis and an oil change fixed it. Does it stall when you idle or when you drive around?
Old Apr 24, 2007 | 02:17 PM
88 shelby girl
That's not a bad question, I have been keeping an eye on the oil level it's cool. It is new oil it only has 700 miles on it since I put it in after the rebuild. It will stall when trying to idle or when I stop when driving. But if I keep on the gas it will get me around. After driving it for awhile it runs fine and idles great... It's the weirdest thing! And it does it randomly with no warning....
Old Apr 29, 2007 | 08:31 AM
outsider75's Avatar
outsider75
hmmm have you checked the IAC valve (idle air valve)?
Old Apr 29, 2007 | 01:09 PM
89Daytona's Avatar
89Daytona
You might want to chage your fuel filter, itcould be clogged. That would starve the engine of fuel.
Old Apr 30, 2007 | 05:23 PM
grungerockjeeper's Avatar
grungerockjeeper
I would just replace every vaccum line on the thing. If it wont idle without keeping your foot on the gas, then thats a dead giveaway that its a vaccum leak somewhere.How long was your car sitting during the rebuild? And did you re-use any of the vaccum lines?My scrambler was doing the same thing after I bought it, and it sat without being driven for a few months till I sold my other truck and all the seals dried up in the carb. A full teardown and rebuild of the carb solved it. Im pretty sure yours is fuel injected, but there may be some rubber seal in the injectors thats partially dry rotted.
Old May 1, 2007 | 01:19 PM
88 shelby girl
Thanks for all the help guys. I will try changing the idle air valve and I am working on going through all thevaccum lines. I did change the fuel filter when I origanally bought the car. I did change all the o-ring on the fuel injectors and put some more fuel injector cleaner. It looks like I will have to spend some time going thru all the vaccum lines LOL I did reuse some of them but most were replaced because they were VERY worn. Probably werent touched since 88. I just have to find the diagram that fits my engine now. Thanks for all your feed back!
