Dodge Daytona The G platform cars that are to this day, fun sporty machines that car modding enthusiasts love to get their hands on, the Dodge Daytona and Chrysler Laser.
vac lines on a 92 daytona
Old Mar 10, 2008 | 08:33 AM
tank21107's Avatar
tank21107
Default vac lines on a 92 daytona
ok im not really much for words but here we go ok got a 92 daytona iroc with the 2.5l turbo was 1/2 tore apart now im trying to put it back together to the vac line now im just lost because i did not take it apart any one know of a way to get rid of some of them lines
Old Mar 13, 2008 | 08:01 AM
bansheenut420's Avatar
bansheenut420
Default RE: vac lines on a 92 daytona
You can find a vac diagram at www.thedodgegarage.com That is THE TD bible. Check that out. Then go over to www.turbododge.com and you can find lost of posts on how people have ran there vac lines.
Hope that helps.
Old Mar 14, 2008 | 08:11 AM
tank21107's Avatar
tank21107
ok thanks ive tryed there but ill look again
Old Mar 15, 2008 | 01:56 PM
bansheenut420
Are all of the lines unhooked? I need a little bit more of a description of what lines are missing. I know where all of them go, but cant begin to tell you if they are all unhooked. lol
Old Mar 16, 2008 | 10:14 AM
tank21107's Avatar
tank21107
there is 2 left on the pass side fender the rest of them are all unhooked but the car should start without the vac lines here is what it does turns over great and then it floods out after about 15 sec but if you can help that would be great
Old Mar 16, 2008 | 10:16 AM
tank21107's Avatar
tank21107
oh and its a 2.5l turbo
Old Mar 18, 2008 | 07:42 AM
bansheenut420
The flooding thing... Is your o2 working correctly? The only vac line that should cause anykind of running problem (other than a vac leak) is the map sensor line.
Old Mar 18, 2008 | 10:25 AM
tank21107's Avatar
tank21107
i have no clue
Old Mar 18, 2008 | 07:11 PM
bansheenut420
You need to check and see that the O2 sensor is hooked up and working. It will be in the exhaust right after the turbo.
Old Mar 19, 2008 | 12:52 PM
tank21107's Avatar
tank21107
how do i check that
