Dodge Daytona The G platform cars that are to this day, fun sporty machines that car modding enthusiasts love to get their hands on, the Dodge Daytona and Chrysler Laser.
'86 Daytona Turbo Z Improperly stored
Old Nov 28, 2015 | 07:20 PM
rbdetails's Avatar
rbdetails
I'll have to try and find diagram.
Old Nov 29, 2015 | 02:04 PM
rbdetails's Avatar
rbdetails
Must not be doing it right because nothing seems to be happening.
Old Nov 30, 2015 | 11:07 AM
Moparite's Avatar
Moparite
Did you find the positive wire? That is connected to the fuel pump so it should work.
Old Nov 30, 2015 | 10:43 PM
rbdetails's Avatar
rbdetails
Yes, the yellow and black wire showed power with the ignition on. So I guess I don't understand how connecting it directly to the positive on the battery would do anything, as the wire already has power going to it.
Old Nov 30, 2015 | 11:13 PM
Black02CrCb's Avatar
Black02CrCb
you could always unhook the fuel line at rail, then drop tank, drain tank, hook an airhose with a rubber nipple end on the fuel line and blow it out.. that way you can reinstall line to tank, reinstall tank, reinstall line to fuel rail, and add new fuel and do it like that. His way would be so much more simple if you can get it to work, otherwise this is probably what you will need to do. Post up pics of it when you can Good luck!
Old Dec 1, 2015 | 09:19 AM
Moparite's Avatar
Moparite
Disconnect the the positive battery lead and keep the ignition OFF! Then run a jumper from the positive on the battery to the positive wire going to the coil. This will run the fuel pump. Using the ignition with the battery hooked up will only charge the system for a second and will not keep the pump running unless the engine is running. You need to bypass the pcm and asd relay and feed power directly to the pump. This works!!! I have done it on both my Daytona and Lebaron.
Old Dec 1, 2015 | 10:24 PM
rbdetails's Avatar
rbdetails
Ok, thanks for the clarification. I thought the ignition needed to be on...
Old Dec 9, 2015 | 06:11 PM
rbdetails's Avatar
rbdetails
Ok, So I am clear: Positive cable should be dis-connected from the battery. Ignition off. Jumper wire from the positive terminal on the battery to the postive wire on the coil. Should the postive be connected connected to the coil? Am I connecting the jumper wire to the positive terminal on the coil?
Thanks again.
Old Dec 10, 2015 | 10:06 AM
Moparite's Avatar
Moparite
Take the positive wire off the coil and run the jumper to it, You should hear the pump run. Don't hook up anything on the coil.
Old Dec 13, 2015 | 12:46 PM
rbdetails's Avatar
rbdetails
Still nothing. I must be missing something in the process.
