Dodge Daytona The G platform cars that are to this day, fun sporty machines that car modding enthusiasts love to get their hands on, the Dodge Daytona and Chrysler Laser.
turbo
Old Jul 20, 2004 | 10:27 PM
elky's Avatar
elky
Default turbo
what generations of turbo's were in what year of cars?
specificly I'm interested in the 85, and also what kinda hp and tq ratings does these cars have? and how long do the turbo's last? and also... anyone know any simple go fast(er) mods?
thanks guys
Old Jul 21, 2004 | 12:46 AM
metalaxeman88's Avatar
metalaxeman88
Default RE: turbo
The 85's had a garret turbo, not sure which one, but its a little bit laggy at times. The horsepower is somewhere around 160's -170's depending upon if it is intercooled and automatic or what, I changed my factory CPU to a Mopar performance one and I push 17 lbs of boost out of my vnt garret, a K&N is always a good idea, if your sure there are no oil leaks ,synthetic oil is a good start, however if you want a good way to find an oil leak, synthetic oil is the way to go, Hope this helps.
-Mike
Old Jul 21, 2004 | 02:09 AM
87Indy500's Avatar
87Indy500
Default RE: turbo
From 1984 thru 1987 Chrysler used a Garrett turbo on all 2.2's. Starting in 1988 the "new" blow thru design 2.2 & 2.5 turbo I models got a Mitsu. made turbo (TOE4). After 1987 the only models that got the Garrett's where the TII, TIII, and TIV with an intercooler (i.e. Shelby Z, Shadow & Daytona VNT, Spirit & Daytona R/T, and anything offered by Shelby except the 1988 CSX-T which got the Mitsu Turbo)
The Mitsu turbo is a good solid unit and spools up allot faster than the Garrett because of its smaller size, but it has problems with spiking at high boost settings. The Garrett is a proven unit and holds steady boost even upwards of 20+ lbs. The Garrett is the best of the 2, but it all depends upon how much boost you are planning on running. If stock boost with a fast spool-up gets your rocks off, a Mitsu maybe the way to go. But if you need a bigger kick in the rear, then the Garrett may be what you want to reach for.
Old Jul 21, 2004 | 11:49 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: turbo
ORIGINAL: elky
thanks guys
Only a non-intercooled turbo was available for '85 and they have failure issues because they run hotter not being intercooled. Just remember to let it idle to cool down before shutting it off and you'll be fine. Here are your 2.2L Turbo I specs:
Horsepower: 146 @ 5,200 RPM
Torque: 168 @ 3,600 RPM
Old Jul 21, 2004 | 03:51 PM
87Indy500's Avatar
87Indy500
Default RE: turbo
Never heard of any failure issues with the 85's. The are all Garrett T3 turbo's with the exception of the Mitsu. Even the TII turbo's use the same turbine housing, but a slightly different compressor housing for the intercooling hose's. Intercooling does not affect the operating temp of the unit. It only cools the forced air before it reaches the intake.
Old Jul 22, 2004 | 03:02 AM
GTCandGTSturbo's Avatar
GTCandGTSturbo
Default RE: turbo
Troy, you really seem to know your stuff - thats refreshing. Are you on turbododge.com by chance?
Old Jul 22, 2004 | 04:52 AM
71RoadRunner
Default RE: turbo
Yes, but being part of the turbocharger it also helps to cool it down much like a heat sink.[sm=smiley2.gif]
Old Jul 22, 2004 | 03:57 PM
87Indy500's Avatar
87Indy500
Default RE: turbo
ORIGINAL: GTCandGTSturbo
I had turbo Dodges back when everyone was too scared to own them and that they only lasted up 50k, but I knew better.[sm=lol.gif] I've had these types of cars since I was 16 (32 now). So if I don't know by now I probably never will.
Yea, I'm on TD.com. (turbojerk)
I hang out there allot it seems.
