4th Gen Ram Tech2009 - 2018 Rams and the 2019 Ram Classic: This section is for TECHNICAL discussions only, that involve the 2009 - 2018 Rams and the 2019 Ram Classic. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Just installed a 2 inch leveling kit on my 2wd. Got longer shocks b/c factory ones were maxed out all the way. Problem is when I hit dip in road, upper a arm strikes side of coil bucket. My question is what does anyone think could remedy this problem, new upper a arms or grinding down the upper a arm alittle bit so it has more room to articulate downwards? Any suggestions would be great.
I would suggest removing the leveling kit. if you really want it level you could also lower the rear a couple inches. , just and idea
