Last edit by: IB Advertising
Browse all: Air Intake and Exhaust Guides
- Dodge Ram 2009-Present: The Ultimate Exhaust Guide
Overview of popular modifications and step by step intructions.
Hemi Tick vs Broken Exhaust Manifold Bolt
Hey guys, I just started getting a ticking sound on my passenger side and it seems to happen for a few minutes after a cold start up, eventually going away. Before yesterday, my truck seemed to run nice and quiet, this is the first time I've heard it. Just wondering how do I know its the Hemi tick vs a broken exhaust manifold bolt?
My truck is an 2010 Ram 1500 SLT with the 5.7, 81k on the odo. I also run Mobil 1 full synthetic on it, but its due for an oil change shortly and I plan on going back with Mobil 1 and a Mopar oil filter.
Exhaust leak is fairly loud and goes away as the engine warms up. Start it up in your garage with your windows open or get out and stand by the front right after you start it. You'll see how load. It also shows up suddenly when the bolt(s) break. This is your issue. Run it to the dealer and they'll verify it. For a 2010 it should be covered under the powertrain warranty at 81K miles.
Rob
Rob
Rob
Rob
Thanks for the help. I'll see if I can sneak it in today.
I've had mine done twice for the bolts and I guess I just don't "get it". Why are "we" having this issue?? Would having grade 8 bolts put in destroy something?? Why can't Dodge seem to get a quality bolt replacement??
This is probably the only complaint I have on our trucks and I don't let it get to me due to the lifetime warranty but damn, this can't be that tough to solve.
It has got to be a quality of parts issue. Heck, the 5.7L Hemi has been around in this form since at least the 2005 Jeep Grand Cherokee (maybe even earlier in Rams) and they didn't have exhaust bolt breakage problems.
Rob
Rob
I had mine fixed a month or so ago, I think they only replaced the studs that were broken, if my warranty expires is there any additional coverage for the new studs that were replaced?
If they fail again will it be at my expense?
do they replace with upgraded studs? if not, wouldn't failure be expected in the future?
Trending Topics
I hope DodgeCares might respont to this thread. I'm real curious about this issue. I'd heard initially in 09 that the bolts were too short and were breaking so they were replace with longer ones.
Do the bolts screw into steel or aluminium?
Are they too short??
Are they cheap metal??
Can a high grade steel bolt be used as a replacement??
Although this issue blows, absolutely love the truck. And the dealer I just took it to in Roseville, MN, I thought handled it really well. They got my truck in without an appointment and got it repaired in a day. I also asked them to fix a headlight issue I was having. They fixed the bolts no questions asked and the headlight ended up being $220 for parts and labor. I'll be picking it up today.
If I had to guess, I'd say the heat cycle characteristics of the heads, manifold, and bolts are not adequately paired. The bolts probably fatigue after many heat cycles and break. You'd think this could be solved pretty easily with different bolts but, as noted, only broken bolts get replaced, so the issue persists.
Rob
Rob
