Do I need to get my Speedometer recalibrated?
So I went from having P265/70R17 tires on my truck and changed them out to P275/55R20's and I was wondering if I should have the speedometer recalibrated so the shift points and such are still proper?
Tire is barely more than a quarter inch taller, nah won't make a bit of difference to the transmission.
Difference on the speedo won't even be enough to mean the difference of getting a ticket or not...
Just what hammerZ71 said James - a couple 10ths of a mph at 62 mph/100kph
http://www.1010tires.com/Tools/Tire-...5R20/275-55R20
Discount tire has a calculator
http://www.discounttire.com/dtcs/infoTireMath.dos
looks like you tire changes makes about a 0.62 mph diff.
old tires 65 mph
new tires 65.62
Not worth the time to change, imo.
old tires 65 mph
new tires 65.62
Trending Topics
not to hijack this thread, but i presume the trucks have something to compensate for what wheels/tires the come with since the difference beween at 265/70-17 and a 275/60-20 is even bigger?
programming or a different gear somewhere?
Back in the day it was a physical geared drive in the trans. You could adjust the speedo by buying a gear-drive with more or less teeth to adjust the ratio. Now, with electrical systems, it's a simple programming step for the dealer.
