Dodge Forum Site Issues and Suggestions Having an issue with the DF software? This is your section!
computer parts
Old Nov 24, 2007 | 05:29 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
Default computer parts
Product Description Unit Price Savings Total Price Update [/align] ABIT Fatal1ty FP-IN9 SLI LGA 775 NVIDIA nForce 650i SLI ATX Intel Motherboard - Retail
Model #: Fatal1ty FP-IN9 SLI
Item #: N82E16813127022
Return Policy:Standard Return Policy
In Stock [/align] $127.99 $127.99[/b] Update [/align] ASUS EN6200TC 512/TD/256M GeForce 6200TC 256M (Effective memory 512M) 64bit (Effective bandwith 128bit) GDDR2 PCI Express x16 Video Card - Retail
Model #: EN6200TC 512/TD/256M
Item #: N82E16814121010
Return Policy:Limited Non-Refundable 30-Day Return Policy
In Stock [/align] $38.99 $38.99[/b] Update [/align] Intel Core 2 Duo E4600 Allendale 2.4GHz LGA 775 65W Processor Model BX80557E4600 - Retail
Model #: BX80557E4600
Item #: N82E16819115032
Return Policy:Processors (CPUs) Return Policy
In Stock [/align] $149.99 $149.99[/b] Update [/align] Patriot Extreme Performance 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model PDC22G6400LLK - Retail
Model #: PDC22G6400LLK
Item #: N82E16820220144
Return Policy:Memory (Modules, USB) Return Policy
In Stock
Mail-in Rebate
would these parts, along with my existing power supply hard drives, case and optical drives be good for a replacement system for the price????, my power supply is a 20 pin, i think 120 watt(i know its a small one but its worked fine up to now)
Old Nov 24, 2007 | 08:48 PM
03neonRT's Avatar
03neonRT
Default RE: computer parts
You'll definitely want a better power supply...
The hard drive(s) and optical drives should swap over without any problems since that mobo is still IDE capable.
Old Nov 25, 2007 | 01:00 AM
SSG Lou's Avatar
SSG Lou
Dude
For what your upgrading to YOU NEED MORE POWER. You might as well buy a new case and power supply. The new MOBO has a 24 pin connector. But mainly MOBO and Graphics card will be power hungry. You also need to look into COOLING. The Floppy connector is in a WEIRD place on that board. I see problems with it(if you still use one). With 4 SATA connectors why use old hard drives.You can geta 160gb for under $50 at that site. Why buy fast equipment just to have HD bog it down.
[sm=americanasmiley.gif]
Old Nov 25, 2007 | 10:28 AM
shrpshtr325
THE ULTI-MOD
because i cant afford much more than that, and how big a power supply do you suggest i get, and do i NEED a new case or is it likely i can make my old one work, the dimensions are bigger than the motherboard listed
and is the floppy connector the fdd connector?? because yes its in a wierd place, but idk if im switching my floppy drive over, i dont use it much(if at all) now that ihave a bunch of flash drives which are smaller and quicker
Old Nov 26, 2007 | 12:11 PM
nickoman01's Avatar
nickoman01
The Only Elite DF Member
first off i have the patriot ram and it si great. i highly recommend that. you will need a new power supply.
here is a pretty decnt calculator to see how much of a power supply you need:
http://support.asus.com/PowerSupplyC...Language=en-us
gotta love asus.
Old Dec 3, 2007 | 01:28 AM
SSG Lou's Avatar
SSG Lou
I wouldn't go under 500wats.It may be more than needed now but as cash flow gets better you may add more stuff. As fas as case it depends. most times you can get cases dirt cheap w/ power supplies.
Old Dec 31, 2007 | 12:15 AM
nickoman01's Avatar
nickoman01
dont go cheap on a power supply. every piece of hardware in your computer is at the mercy of the power supply, so you dont want a ****ty cheap power supply unless you are building a ****ty cheap computer.
