Dodge Forum Site Issues and Suggestions Having an issue with the DF software? This is your section!
TCP connection help needed.
Old May 3, 2008 | 04:22 PM
steve05ram360's Avatar
steve05ram360
Default TCP connection help needed.
how do I setup a port on a remote pc to be a listener? I can do it thru my s/w however I need to try to establish a connection w/o loading any of my stuff on an embedded system. any help would be greatly appreciated...
Old May 3, 2008 | 04:25 PM
steve05ram360
Default RE: TCP connection help needed.
maybe I should expand on this some...
I need to connect to a test sytem and be able to execute script files that reside on it's hard drive. again w/o loading any of my s/w onto it. I will also need to read back the output files off that system to examine the test results...
Old May 21, 2008 | 07:34 AM
timsalas's Avatar
timsalas
What OS is this test system running? You said embedded system, are we talking PDA embedded type system? Does that System allow for SSH? PM Me mebe I can help ya figure it out.. :-)
Old May 21, 2008 | 07:35 AM
timsalas's Avatar
timsalas
Woa, this is an old post.. I just discovered this wonderfull geeky corner ( Im a self declared geek)
Old May 21, 2008 | 08:24 AM
steve05ram360
yup, old post problem solved... (on a different piece of test equipment... the one I will use is out for repair)... thanks though much appreciated.
