Dodge Forum Site Issues and Suggestions Having an issue with the DF software? This is your section!
1999 dodge 2500 cummins
Old Sep 18, 2010 | 03:52 AM
samsampson's Avatar
samsampson
Default 1999 dodge 2500 cummins
My sons 99 2500 cummins is not registering RPM's on the gauge. It does run funny but all of the sudden it will register and run fine. The check engine light has been on but it is flashing code of hot engine and hot transmission. Does anyone know what this is?
Old Dec 14, 2011 | 07:52 PM
flguy1856's Avatar
flguy1856
Hey did you figure out what the problem was? i am starting to have that same issue with the RPM gauge, i haven't been able to get a computer to see what codes the check engine light is showing
Old Dec 20, 2011 | 06:47 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Hello. Welcome to DF. However, you have not received any responses to your query b/c it's in a section that does not have higher signal-to-noise ratio.
Post your query in the following forum instead for Cummins Truck.
https://dodgeforum.com/forum/dodge-cummins-diesel-88/
Old Oct 13, 2013 | 09:59 AM
limo12955's Avatar
limo12955
I have a 1996 dodge 3500 8.0 v10 and would like to install a 5.9 diesel. Would everything bolt up and does anyone think it would interchange easily.
Old Oct 13, 2013 | 10:54 AM
All, this section is for posting issues with the Dodge Forum website. Not technical, vehicle specific questions. Please visit the appropriate technical section for the vehicle you drive and post your questions there.
