Dodge Intrepid The sporty car that recently left the Dodge lineup, the Dodge Intrepid. With it's smooth look and comfortable ride, the Dodge Intrepid can still command attention.
How to open hood with busted cable ???
Old Jul 14, 2007 | 10:48 PM
Checkmate's Avatar
Checkmate
Default How to open hood with busted cable ???
2000 intrepid hood latch cable busted...Now what?? How do I open this hood ? There seems to be NO way to get to the latch.
Old Jul 18, 2007 | 12:40 PM
yiranhu's Avatar
yiranhu
Default RE: How to open hood with busted cable ???
Can you reach that cable at all? If you strip off a little bit of the outside plastic covering on the cable and take a plier to grab the metal wire on the inside, you can just pull on it to get the latch to release. If you can't reach the cable at all, then you might be in trouble...
Old Aug 15, 2007 | 06:28 PM
dodis's Avatar
dodis
First post, been getting good info, now have some to post!
Our 99 had the cable-clip at the latch come loose so the entire cable just slid into the latch, wouldn't open. 350 miles from home, all I could find was a 6" pegboard hook (rod). I poked around inside the latch until I caught the lever the cable is attached to, and was able to trip it to get the hood open. A long thinscrewdriver should do as well. Couldn't see what I was doing, so I can't offer a better description.
Mike
