Dodge Intrepid The sporty car that recently left the Dodge lineup, the Dodge Intrepid. With it's smooth look and comfortable ride, the Dodge Intrepid can still command attention.
intrepid 2000 starting problem
Old Jun 28, 2010 | 09:03 PM
penco8's Avatar
penco8
hey m8 i bolught the map sensor in a junk yard .. now the car runs but when i start the car the rpm is too high n then when i drive n stop the rpm get too low .. are this symtoms normal????
Old Jun 29, 2010 | 04:58 PM
kurts2's Avatar
kurts2
No, it sounds like a bad sensor (or maybe wrong part number). The map controls timing like the vac advance in the old days.
Old Jun 29, 2010 | 07:24 PM
penco8's Avatar
penco8
well the car now is running good the other problem i have is the steering it make a noise only when i press the gas pedal but the noise is beteween 10-20 mph after that the noise die n runs good mecanic told me it was the steering pump would .. the steering pump vibrates when i press the gas pedal ???? why
sorry for my english guys
Old Jun 30, 2010 | 12:12 AM
kurts2's Avatar
kurts2
Is it a squeal?
Old Jun 30, 2010 | 11:25 AM
penco8's Avatar
penco8
what do squeal mean ????
Old Jul 1, 2010 | 08:31 PM
kurts2's Avatar
kurts2
It is a sound that is high pitched, shrill and can be caused by a loose or bad belt. To verify, spray belt dressing on it while running and see if the sound goes away.
Old Jul 2, 2010 | 04:09 AM
penco8's Avatar
penco8
are this are the symptoms of a bad serprentine belt???\\\\\
lose power steering, power brakes,your battery will not charge, your engine will overheat. The belt turns your water,power steering,power brake pumps as well as your alternator which provides power.??????
Old Jul 2, 2010 | 08:54 AM
kurts2's Avatar
kurts2
[QUOTE=penco8;2187055]are this are the symptoms of a bad serprentine belt???\\\\\
lose power steering, power brakes,your battery will not charge, your engine will overheat. The belt turns your water,power steering,power brake pumps as well as your alternator which provides power.??????[/QUOTe
Not really... a loose belt will squeal with some preformance loss. A broken (snapped, cut etc) belt will cause system loss. Also some of the systems you listed for a "bad serprentine belt", would not be affected on your car. Your brakes are boosted by engine vacuum and your water pump is driven by the timing chain (chain for 2.7 engine, for 3.5 it's the timing belt) therefore your engine would not have an overheat. Neither of these systems would be affected by a broken serprentine belt.
Old Jul 2, 2010 | 10:54 AM
penco8's Avatar
penco8
ok what about lights on dash it looks light go down n when i prees gas pedal the lights go up could this be the belt or what do i check to fix this issues
Old Jul 3, 2010 | 12:35 AM
kurts2's Avatar
kurts2
Ok, have your charging system tested at an auto parts store for free and let's go from there. That will answer many of the basic problems.
