Dodge Intrepid The sporty car that recently left the Dodge lineup, the Dodge Intrepid. With it's smooth look and comfortable ride, the Dodge Intrepid can still command attention.
how do you test the oil pump?
Old Sep 8, 2011 | 10:30 PM
vedlinyrim's Avatar
vedlinyrim
Default how do you test the oil pump?
I have a 2002 Dodge intrepid SE 2.7L, I want to test the oil pump to see if its working before i go out and purchase one for $200 bucks. Is there a way to test to see if its working?
My problem could be as simple as a $50 tube and screen although I dont want to rip everything apart until I have checked every single option i can first.
Old Sep 21, 2011 | 12:42 PM
misfitdakota_95's Avatar
misfitdakota_95
well, get yourself and oil pressure gauge, remove the oil pressure sending unit on the right side of the engine and measure your pressure. You can pick up a gauge for cheap at harbor freight tools (usually around $20). At idle, the MINIMUM oil pressure should be 5 psi according to the factory service manual and between 45-105 psi @ 2000 RPM and higher. For me the best rule of thumb to remember oil pressure is 10 psi for ever 1000 RPM.
