Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
How to set timing on 2009 journey 2.4 dual cam
Old Mar 17, 2014 | 11:18 AM
BigWoods75's Avatar
BigWoods75
Default How to set timing on 2009 journey 2.4 dual cam
I am having trouble setting the timing on my 2009 journey 2.4 SUV can anyone help
Old Mar 17, 2014 | 11:33 AM
How are you trying to adjust the timing? Timing is controlled by the PCM. Cannot be adjusted like the old days by turning the distributer. Would need a tuner. What are you doing or have done to need to adjust the timing?
Old Mar 17, 2014 | 11:44 AM
BigWoods75's Avatar
BigWoods75
I was told that I would have to take it to a dealer to get the timing marks
Old Mar 17, 2014 | 11:58 AM
BigWoods75's Avatar
BigWoods75
I put a head gasket on my car because it was leaking
Old Mar 17, 2014 | 09:37 PM
steak59's Avatar
steak59
and
Or if you have everything off then
Note: If you blew a Head Gasket due to Over heating, Make sure you check the straightness of the head with a Straight edge. Other wise you are wasting your time doing the Head Gasket.
Also, these heads on the 2.4L has no machining tolerance, if they are warp, you replace it. Or find a Machine shop that is equipped to straighten out warp heads.
Old Mar 19, 2014 | 12:12 AM
master tech's Avatar
master tech
Site Moderator & Tech
I got you pm. But you have the timing mark setup by steak59. Thank you. Your timing is adjusted by the intake and exhaust camshaft phasers. So the phasers are at DTC until you are driving. Then either one or both can adjust 5 degrees BTC or 5 degrees ATC. That why we use either 5/20 or 5/30 oil. The incorrect oil will kick the check engine lamp on giving you a I think is P0520 code.
Old Sep 28, 2021 | 04:15 AM
Chaz caswell's Avatar
Chaz caswell
New Member
Quote
well my car is running like crap and it has 20 codes
Old Sep 28, 2021 | 07:22 AM
Originally Posted by Chaz caswell
Quote
And???
