Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
Journey leaking coolant help
Old May 22, 2014 | 08:16 AM
yong7801's Avatar
yong7801
Default Journey leaking coolant help
I have a 2009 Dodge Journey that is leaking engine coolant. I know the plastic wye connector circled in yellow is cracked and leaking so that needs to be replaced. I also have an unknown drain line circled in red that is leaking coolant, does anyone know what the drain line is connected to? Thanks for any help in advance.[IMG]http://<a href=http://s1155.photobucket.com/user/yong7801/media/2014-05-22%2007.50.50.png.html target=_blank>Name:  2014-05-22%2007.50.50.png
Size:  747.1 KB[IMG]https://dodgeforum.com/forum/<a href=http://s1155.photobucket.com/user/yong7801/media/2014-05-22%2007.50.50.png.html target=_blank>Name:  2014-05-22%2007.50.50.png
Size:  747.1 KBName:  2014-05-22%2007.50.50.png
Old May 22, 2014 | 09:42 AM
Pics dont work. Whatever is broken or cracked needs to be replaced. Go from there.
Old Sep 18, 2015 | 12:38 AM
stefanst's Avatar
stefanst
[QUOTE=yong7801;3167484]I have a 2009 Dodge Journey that is leaking engine coolant. I know the plastic wye connector circled in yellow is cracked and leaking so that needs to be replaced. I also have an unknown drain line circled in red that is leaking coolant, does anyone know what the drain line is connected to? Thanks for any help in advance.[IMG]http://<a href=http://s1155.photobucket.com/user/yong7801/media/2014-05-22%2007.50.50.png.html target=_blank>Name:  2014-05-22%2007.50.50.png
[IMG]https://dodgeforum.com/forum/<div style=&quot;width:480px;text-align:right;&quot;><a href=&quot;javascriptb/b:void(0);&quot; target=&quot;_blank&quot;><img src=&quot;a href=http://pic.photobucket.com/share/icons/embed/btn_geturs.gif&quot; target=_blankhttp://pic.photobucket.com/share/icons/embed/btn_geturs.gif&quot;/a style=&quot;border:none;&quot; /></a><a href=&quot;a href=http://s1155.photobucket.com/user/yong7801/library/dodge&quot; target=_blankhttp://s1155.photobucket.com/user/yong7801/library/dodge&quot;/a target=&quot;_blank&quot;>
Old Sep 18, 2015 | 08:45 AM
bigtsr's Avatar
bigtsr
[QUOTE=stefanst;3264472]
The "Y"is a much posted fault, the other if it is a drain should not be leaking coolant but clear water.
Old May 26, 2022 | 01:22 PM
jaymclure's Avatar
jaymclure
What is the hose circled in red and why is it leaking coolant. I have the same issue. Started all at once. I can't tell if the other hose joints are leaking or if it's just the open hose above them. I was worried I had a bad head gasket but maybe it's much simpler. What are those is that drain hose from?
