Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
2009 emergency brake light
Old Jun 1, 2014 | 08:57 PM
Ssrmadrid's Avatar
Ssrmadrid
Default 2009 emergency brake light
Emergency brake light is staying for a few miles then goes out. 2009 journey. Any ideas?
Old Jun 2, 2014 | 08:13 AM
Fluid low, switch out of adjustment, pads worn.
Old Jun 3, 2014 | 12:25 PM
webslave's Avatar
webslave
Making the assumption that you use the emergency brake when you park... Try parking without using it. If the light stays off the next time you drive it, I would first look at the switch (pressure) that the pedal presses against. Most likely it is sticking and it takes the vibration of the car traveling a few miles to get it to release turning the indicator light off. If that is the case, try spraying a dry lubricant on it and pressing in a couple of times to spread it around. May be all that is needed.
