Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
09 dodge journey sxt coolant leak from engine
Old Feb 9, 2017 | 09:55 PM
randygeb's Avatar
randygeb
Default 09 dodge journey sxt coolant leak from engine
Coolant leaking from hole in right side of engine....input?
Attached Thumbnails 09 dodge journey sxt coolant leak from engine-20170207_154338.jpg
Old Feb 9, 2017 | 09:57 PM
Can't tell a thing from that picture
Old Feb 9, 2017 | 10:08 PM
randygeb's Avatar
randygeb
Small hole hard to see almost seems like a bolt hole. Right side of engine...coolant literally shoots out
Attached Thumbnails 09 dodge journey sxt coolant leak from engine-20170207_154329.jpg   09 dodge journey sxt coolant leak from engine-20170207_154338.jpg   09 dodge journey sxt coolant leak from engine-20170207_154345.jpg
Old Feb 9, 2017 | 10:49 PM
What part of the engine is that?
Old Apr 11, 2018 | 06:45 PM
accessoires's Avatar
accessoires
Hi, I want ton know if someone have a fix for this trouble, because I have the same problem.
Thank you.
Old Apr 12, 2018 | 05:35 AM
accessoires
i finaly found;
""Ok, you have a freeze(expansion) plug that is leaking. You have two located towards the top sides of the engine block behind the flywheel. To replace the transmission has to be dropped in order to remove the torque converter(or clutch if manual transmission), then remove the flywheel to access the freeze plugs to replace the one that is leaking.""
https://www.justanswer.com/dodge/925...g-coolant.html
Old Jan 23, 2020 | 06:26 PM
Matt7039's Avatar
Matt7039
Default Hi
I have the exact same thing going on, did you ever pinpoint the problem?
Old Jan 16, 2024 | 10:34 AM
Fast101's Avatar
Fast101
It's at the front or the back of the engine one it's leaking from the rear of the engine
