2010 journey won't start
08-08-2017, 12:39 PM
on
Our journey won't start. Tried the neutral trick, checked the IOD fuse, replaced the starter, new battery, tried another PCM, tightened all the grounds....any ideas? It ran fine last time it ran...next day, nothing just clicks.
08-08-2017, 02:09 PM
Dodge Forum Administrator
Tightened the positive connections?
08-08-2017, 03:07 PM
on
Quote:
yes...one of the first things they checked
08-08-2017, 03:37 PM
Do you have the keyless FOB? Who is doing the work and troubleshooting on the vehicle? The dealer?
08-08-2017, 04:49 PM
on
Key fob.. .local mechanic...and he's sent it on to a local shop for more intense diagnostics
08-13-2017, 01:57 PM
on
Ok...finally got it started....but won't go over 20km. The electronic throttle control light is on as well as the ESP....any ideas?
08-13-2017, 05:33 PM
Limp mode. Dealer or shop is your best bet.
08-13-2017, 05:58 PM
on
Thanks....we were wondering if we should try disconnecting the battery in case the computer is scrambled with all the work that's been done recently?
08-13-2017, 06:35 PM
That's not a bad idea. Will reset everything. Can't hurt to try.
08-13-2017, 07:01 PM
on
Great....we'll try it first.....thanks for your help
