Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
Heater problems
Old Dec 21, 2017 | 03:02 PM
peev's Avatar
peev
Default Heater problems
Hi. I have a 2010 journey with dual climate control . My problem is I have some heat coming out the drivers side vents and none coming out of the passengers side. I have flushed the heater core and found nothing . Took it to my locally mechanic he scan the heating system and found no faults. So he did a recalibration on the actuators and it worked and after a few minutes it went back to the same problem . Any ideas. Thanks.
Old Dec 30, 2017 | 04:50 AM
Heather Marsel's Avatar
Heather Marsel
Following*
im having the same issue with my 2012 Dodge Journey!
i have changed the thermostat and done 2 heater core flush...
at at this point I’m looking at replacing the heater core... ugh.
Old Dec 30, 2017 | 03:11 PM
peev's Avatar
peev
I took it to the dodge dealer and they checked the system . Found no faults electrically. they say its partially plugged heater core so it goes in next Tuesday to have the heater core replaced. I'll let you know how I make out.
Old Jan 5, 2018 | 07:24 PM
peev's Avatar
peev
They replaced the heater core . And the problem seems to be resolved
Old Jan 5, 2018 | 10:23 PM
Heather Marsel
Oh I’m glad! Thank you for letting me know! Truly a big help!
Old Jan 5, 2018 | 10:37 PM
peev's Avatar
peev
The dodge dealer said they are replacing a lot of heater cores. That nobody does a coolant flush anymore . The heater core is so low in the vehicle that the solids in the coolant settle in the heater core. It's been -22 degrees Celsius since it has been repaired and the vehicle is warm .
Old Jan 6, 2018 | 12:17 AM
Heather Marsel
Yeah I did a flush just over a week ago (non dealership) and it helped thank goodness because that’s when we had our -22 weather! Now we have a chinook so plus 1! I’m planning to get the heater core replaced around the 25th this month.If you don’t mind me asking, how much did it cost you and how long did it take?
Old Jan 7, 2018 | 05:29 PM
peev's Avatar
peev
t cost $1100 . That included a heater core $288 and removing the ac refrigerant and refilling the ac to specs and some antifreeze. Dropped the vehicle in the morning and pick it up the next day I think it was about 10 hours. The heater blows more air around because the temp sensors in the vehicle are not confused trying to tell the doors what position to be in. Good luck. Its a lot of money but we are happy we did it . It has been in the -20s since we got it done and its toasty warm in the journey since.
