Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
2016 Dodge Journey ABS/Traction Light
Old Feb 23, 2018 | 09:47 AM
foxxtaylor1's Avatar
foxxtaylor1
Smile 2016 Dodge Journey ABS/Traction Light
Hello there, I have a 2016 Dodge Journey with about 36,000 miles on it. The other day my ABS light and Traction control light came on at the same time.
The traction button is not able to turn on or off and the cruise control button no long works.
Does anyone have any ideas on what I should do, or have had the same issues.
Thanks
Old Feb 23, 2018 | 09:52 AM
You can inspect the wheel sensors to see if there is anything (dirt, mud, snow, etc) interfering with the operation. Otherwise, you will need to find out what the codes are to isolate the issue. Dealer or a shop has the proper scan tool to read ABS codes. Or, I believe you can buy code readers for ABS now. Also, make sure your tires are the same size and properly inflated.
Old Feb 23, 2018 | 09:55 AM
foxxtaylor1
Thank you, I have a read tool. I will have to hook it up and see. I will check the sensors thank you
Old Feb 23, 2018 | 06:10 PM
foxxtaylor1
Okay, did a code read. Not one single code came up. Where about is the wheel sensors at?
Old Feb 23, 2018 | 07:00 PM
What kind of scanner are you using? The wheel sensors are on the wheel hubs.
Old Feb 23, 2018 | 08:36 PM
foxxtaylor1
OBD2 Actron Auto Scanner plus.
Old Feb 23, 2018 | 09:11 PM
If you read the reviews on that scanner, people complain that one won’t read abs codes. If your light is on, there is a code. That scanner just might not be able to read it.
Old Feb 23, 2018 | 09:30 PM
foxxtaylor1
Okay thanks I will have to see if my sister has a different one then me. Thanks a lot
Old Jun 18, 2018 | 01:45 PM
Catlin Jordan's Avatar
Catlin Jordan
I am having this problem with my wifes car. Did you ever figure out the problem with yours?
Old Oct 14, 2018 | 06:20 PM
Summer Braswell's Avatar
Summer Braswell
Default ABS light 2016 Journey
The light came on and I went to a dealership and had it repaired. It was a brake sensor. Now it’s on again. Started flickering and has been pretty consistent. Trouble braking while it’s on. Wondering if there’s a recall.
