Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
2009 Journey - no turn signals when using column stalk
Old Jul 2, 2019 | 06:45 PM
covert81's Avatar
covert81
Question 2009 Journey - no turn signals when using column stalk
Hi everyone,
2009 Journey SXT. On my drive in to work today everything was fine. On my way home, from a cold start sitting all day, the turn signals won't turn on when putting the indicator up or down for left or right turns. No light or sound, it clicks in place and will reset to centre when making a turn but nothing is apparently happening. Hazards work fine as does locking or unlocking the door with the keyless (lights flash, horn chirps, lights for the indicators blink on the dash). Headlights turn on and off from the same stalk, as does pushing forward on it to activate high beams. I tried turning it off then turning it back on, no change. Left it for about 15 minutes and tried again, no change. Is the switch is bad? I checked the owner's manual and see no fuses for the turn signals, just the marker/side lights (unless that is what is meant) but I doubt it's a fuse due to both sides ceasing to function at the same time.
I've never had this issue before in this car, I had a similar problem once in another car and it was the stalk that was bad, a broken plastic contact or something.
No work done lately, it's due for an oil change but that's it. Battery replaced about 2 months ago, weather was fine today, around 28-29 Celsius and a bit of rain throughout the day but nothing out of the ordinary for this part of the world.
Any assistance would be appreciated.
Old Jul 3, 2019 | 06:37 PM
covert81's Avatar
covert81
I fixed it.
I took the column apart, popped the plastic off the top, and just unplugged and reconnected the 2 connectors attached to it. Voila, they started working again.
Old Nov 24, 2024 | 01:34 AM
Saddodge's Avatar
Saddodge
Originally Posted by covert81
I fixed it.
hi , problem never come back ?
Old Nov 30, 2024 | 08:27 AM
covert81's Avatar
covert81
It never came back, but we ended up having too many problems with it, we left it for a year then sold it for scrap.
The fuse situation became kind of untenable. I had to pull fuses for the horn since it would randomly go off and not stop till the fuses were pulled. The lights would randomly turn on and off. The door locks would randomly lock and unlock. The windows would refuse to go up or down. It also developed the blend door flapping issue and at the time, it just didn't make sense to spend more money to repair it. We are much happier now moving to a different brand and model and while I miss some of the things domestic car makers give us and we take for granted, I've adjusted.
