Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
A/c issues
Old Sep 1, 2022 | 03:26 PM
redpopo's Avatar
redpopo
Default A/c issues
I have a 2019 Dodge Journey sxt! The a/c compressor was replaced last year and it was down coolant but no leaks found! This year I brought it to the dealership and it was bone dry and again no leaks found even with the dye! Both dealership and warranty company admitting it’s not normal but won’t cover because nothing is being found! Please help!!
Old Sep 1, 2022 | 04:09 PM
So what is the exact issue?
Old Sep 1, 2022 | 04:10 PM
redpopo's Avatar
redpopo
The a/c wasn’t working the system went bone dry and they can’t tell me why except they are finding no leaks
Old Sep 1, 2022 | 04:55 PM
redpopo's Avatar
redpopo
What would cause an a/c system with no leaks be bone dry?
Old Sep 2, 2022 | 07:43 AM
How are you determining its “bone dry”? Have you opened the system to look? What are the pressures? Have they vacuumed the system and refilled it?
Old Sep 2, 2022 | 08:00 AM
redpopo's Avatar
redpopo
its at the dealership! They ran diagnostics! Told me the system was bone dry! But can’t find a leak! Refilled and charged and added dye! Still can’t find a leak! Everything I’m reading is that’s not normal especially being only 3 yrs old with less than 50k miles should not be having issues like that! Dealership wants nothing more to do with it and to give it back! With an oh well attitude! So I’m looking for possible causes! Cause I’m at a loss with no help from them
Old Dec 18, 2022 | 03:58 PM
Shadow_Death's Avatar
Shadow_Death
So normally I wouldn't consider this issue because your journey is so young but just in case let's go.
How long does your AC hold up after they fix it before it quits working? Is it a few months? There is definitely a leak because they said the system was dry suggesting that it's purging somewhere. Likely they're looking outside at the lines or the coil. You would know of it was purging inside because you would smell it and it would coat your windshield. So my thought is the one place people always overlook. Has anyone checked the Schrader valve inside the low side port? It's the smaller of the two ports. Sometimes the rubber O-Rings in these calves get pinched and they leak.
