Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
3.6L VVT Journey Miss Fires Cyl 1,3 & 5
Old Jul 9, 2024 | 10:49 AM
ss4faith's Avatar
ss4faith
Default 3.6L VVT Journey Miss Fires Cyl 1,3 & 5
I recently noticed some rough idle at times with my Journey, then into a short drive at 50mph the engine started missing seriously and the check engine was light flashing on/off. I limped home and the OBD scan showed cylinders 1,3 & 5 misfires and crankshaft to CAM misalignment. HELP!!!!
Old Jul 9, 2024 | 11:43 AM
How many miles on it? Could be any number of things, stretched chains, failing sensor, etc.
Old Jul 9, 2024 | 12:41 PM
Last tune up?
Old Jul 9, 2024 | 03:16 PM
ss4faith's Avatar
ss4faith
147K miles, tune up at 100k
Old Jul 10, 2024 | 07:52 AM
You need to get it to a shop.
Old Aug 21, 2024 | 01:29 PM
msaez9's Avatar
msaez9
Default Same issue
I had the same issue but to cylinders 3 and 4. It was the coil packs that needs to be replaced so I had all 6 replaced. Car runs smooth again
Old Aug 21, 2024 | 04:01 PM
ss4faith's Avatar
ss4faith
To make a long story shorter, I replaced my coils finding a burnt one in the process and have had no problems since. The 1st shop I took it to said I needed a new engine based only on the OBD scan that the crankshaft & camshaft were misaligned, but the engine was running fine with no engine noise……
Thanks for your reply!
Old Aug 21, 2024 | 07:42 PM
dodgetruck2's Avatar
dodgetruck2
I wouldn't rule out plugs. My Durango got drivers side coil packs (one failed, replaced all 3) and all 6 plugs at 85-90k. Just this last winter has random misfire again at 145k, replaced other 3 coils since they hadn't been. Fixed it for a week maybe, issue returned. (Had previously serviced rockers due to roller failure, worried I messed up the cams). Decided to pull plugs, my plugs with 50k on them had already burned out to .085"+, new plugs and good to go, hopefully got better ones this time
