Bigger tire for SXT
Old Nov 7, 2004 | 01:23 PM
MikeyB's Avatar
MikeyB
Default Bigger tire for SXT
I'm planning to purchase an SXT for my better half in the near future and would like to upgrade to better (performance) tires. Planning to go with either the Dunlop Sport A2 or the Pirelli P Zero Nero in 235/55/17. Will it fit ok with the stock wheels?
MikeyB
Old Nov 7, 2004 | 03:56 PM
MagnumRT's Avatar
MagnumRT
Default RE: Bigger tire for SXT
Are you going for a bigger tire or just a better tire?
Why not use up the stock tires first, then buy new tires?
My stock tires on my RT do me just fine.
Bob
Old Nov 7, 2004 | 04:42 PM
356MAGNUM's Avatar
356MAGNUM
AS ON TIRERACK.COM
215/65R17 (Stock SXT)
28.0038" diameter
17X7" rim
tire width 8.6"
225/60R18 (stock on RT)
28.6299" diameter
18X7.5" rim
tire width 9"
235/55R17
27.1772" diameter
rim 7-8.5" so they fit on stock rims
tire width 9.2"
If a RT owner could do a lock to lock check on the front tires and see if there is about a 1/4" room then they should fit.
There is also the wheelspacer option if it dont. Also there is some debate on wether or not the PCM can be re-programmed for different tire sizes or only between the stock tire sizes. There is an .8266" difference on heigth, which means there will be .4133" more gap at the wheelwells than stock.
Old Nov 7, 2004 | 05:08 PM
dodgemech's Avatar
dodgemech
ORIGINAL: 356MAGNUM
No debate, the tire size can be reset but only to a size that offered from the factory. Best way to to it have the dealer set the size to the closest thing that was available. A half inch either way shouldn't hurt anything.
Old Nov 8, 2004 | 07:47 PM
356MAGNUM's Avatar
356MAGNUM
Thanks for answering the reprogramm debate for me. I have be deploying and have had a hard time keeping up with the treads.
Old Nov 10, 2004 | 06:38 PM
phantom505's Avatar
phantom505
I put Blizzacs that are 235/55R18. I haven't noticed any problems other than the car wants to drift even more now..... the alignment never did seem quite right and with the wider tires it seems even moreso....
The car defineatly looks meaner being about with the tires being about a 1/2" shorter.
