Worlds quickest N/A Magnum R/T
Old Dec 14, 2007 | 06:44 PM
lblackneon's Avatar
lblackneon
Default RE: Worlds quickest N/A Magnum R/T
Did u get a slight weight reduction or is 4485 the stock weight?
Old Dec 14, 2007 | 07:57 PM
65standard's Avatar
65standard
ORIGINAL: lblackneon
this was my race weight on that run. i removed the spare and jack only, stock 18" in front and sxt 17" w/drag radials in back, plus 160lbs for driver weight and 1/2 tank of 93 octane.
my normal everyday weight with the spare, jack, driver,and 20" wheels is 4620lbs.
Old Dec 14, 2007 | 08:13 PM
65standard's Avatar
65standard
ORIGINAL: t91wheeler
....I'll be very curious what you can do with the new tune you mentioned and a higher stall converter.That would be awesome if you could break into the 11's...
i am thinking 12.20s with the perfect tune and a PI 3200 stall converter. i think i need some lower gears to get into the 11s. i only have 2.82 gears now. but with some 3.42 gears, 11s should be obtainable.
Old Dec 16, 2007 | 03:28 AM
9SEC6SPD's Avatar
9SEC6SPD
another newb question, is the 2.89 gear the stock ratio, i am assuming it is.
Old Dec 16, 2007 | 10:48 AM
65standard's Avatar
65standard
2.82 is stock for a R/T
2.87 for an SXT
3.06 for an SRT
3.07 for an AWD R/T (but are 6 cylinder gears)
3.64 very early 300 v6
