tire pressure
Old Jan 21, 2008 | 10:14 AM
weitekampt's Avatar
weitekampt
Default tire pressure
What tire pressure do you guys run? I live in illinois and it is dead cold right now. But I have goodyear assurance tires that came stock on it. The tires say 44lbs cold. The door says something like 32 or 35. I have been running 40 front and 38 in rear for the first year. But I have never understood if you are supposed to go by the tire manufacturer or by the car manufacturer. Is the suspension tuned for a softer tire or should I keep a little more pressure in them. I need to check them again since it has gotten so cold so any information would be very helpful.
Todd
Old Jan 21, 2008 | 10:33 PM
65standard's Avatar
65standard
Default RE: tire pressure
i run at 44psi
Old Jan 21, 2008 | 10:43 PM
weitekampt's Avatar
weitekampt
Thanks 65, I will air them up just a bit. It does ride better when they are softer, but I think I have lost 1 or so mpg since I have dropped pressure. One question I do have for you, are they stock size tires you are running? Looks like you have custom wheels. I take it you go by the sidewall of the tire.
Thanks again for the input.
Old Jan 26, 2008 | 07:13 AM
thankuhal's Avatar
thankuhal
I run Nitto tires. Door jam says 33 psi. I run mine a bit low. I let the heat bring the up the proper pressure. When I crank mine up in the morning, gauge reads 27-29. Once I get rolling, within 10 mins or so, I am right at32-34.(cold weather)
[IMG]local://upfiles/71292/549F76579F3D43568F10FE67FA6DD48C.jpg[/IMG]
[IMG]local://upfiles/71292/3C5F307E323F41C2A1E1F932A1FA539B.jpg[/IMG]
Old Jan 26, 2008 | 09:49 AM
fr8hauler's Avatar
fr8hauler
I would think that 38-40 psi on stock tires would make it ride like brick.I have mine at 32psi with 18" Goodyear Assurance.
Old Jan 26, 2008 | 10:57 AM
Pennsymagnumguy's Avatar
Pennsymagnumguy
I run 35 PSI all around.
Old Jan 26, 2008 | 04:28 PM
Deakniles's Avatar
Deakniles
I checked mine it was 35 psi cold way cold in fact about 25 degreess outside. Door sticker from continential said 30 psi bled the tires down to that pressure. I think the max was like 38 psi i'll look again. My mileage sucks sinceI have 400 pounds of weight in the back for traction.
Deak
Old Jan 27, 2008 | 09:55 AM
kettlinton's Avatar
kettlinton
I run 36 psi, i have 22inch wheel with 265/35/22 tires. has a nice ride to it.[/align][/align]
