Magnum rattled like a tin can
Old Jan 17, 2005 | 06:23 PM
AZhemi's Avatar
AZhemi
Default Magnum rattled like a tin can
We have had our manesium pearl RT for 14k miles now and there was always a rattling coming from the rear area.
Well, i found it was coming from the rear hatch and pulled it all apart.
The clips to hold wire connectors were doing most of the rattling alont with some cables. I zip tied them up and made sure they were quiet before putting this back together. However, i am planning on using some sound deadening stuff like dynamat or equivalent back there. The entire rear area of my magnum is loud, and always has been. I plan to remove the spare and throw down some dynomat and under the rear hatch panel too.
Figured i would pass along this tip for hunting down a rattle.
Old Jan 17, 2005 | 10:04 PM
2005 Magnum R/T Hemi's Avatar
Default RE: Magnum rattled like a tin can
When was your car made? I have never experienced any rear noise from the back of my Magnum. I was just thinking that some insulation was left out on your vehicle for some reason.
Old Jan 18, 2005 | 01:40 AM
MikeyB's Avatar
MikeyB
I noticed this last weekend while testing driving several Magnums. Drove an SXT and it had a lot of wind noise coming from the rear of car at highway speeds. The RT I ended up buying has no wind noise at any speed.
MikeyB
Old Jan 18, 2005 | 02:25 AM
Black RT's Avatar
Black RT
Make sure the rear hatch door is shut tight>>I was looking at a magnum a few months ago. I was in back seat and could see light comming in at bottom of hatch door on both sides it was not shut down tight.
Buddy in KY
Old Jan 23, 2008 | 03:34 PM
lilzztopjr's Avatar
lilzztopjr
hi there felow magnum owner i have just purchase a 2005 rt manesium pearl just like you an i have the same noise coming from the rear did it work for what you did an how hard is it the get to the lacthe area becuase it is driving me nut any help would be great thanks
Ed
Old Jan 23, 2008 | 04:53 PM
darkrt's Avatar
darkrt
Had same rattle. Turned out rear latch need adjustment,was not latching down tight.
Old Jan 28, 2008 | 09:51 PM
lilzztopjr's Avatar
lilzztopjr
thanks is it easy to ajust an i am suming i have to take that back panel offisd it just to three screwany help, would be great thanks
Old Jan 29, 2008 | 09:18 AM
darkrt's Avatar
darkrt
Adjustment of striker plate. Remove panel,pops off at the bottom,srrews at top. Loosen bolts on plate and move slightly away from you. Re-tighten and test hatch. Repeat until you get the adjustment right.
Old Jan 31, 2008 | 12:46 PM
Jellobrand's Avatar
Jellobrand
Wind Noise.... Station Wagons are prone - the back is accessible to the passenger cabin. No Rattles Here -
Old Jan 31, 2008 | 08:28 PM
god_complx's Avatar
god_complx
I have had no issues either, well, my license plate holder did rattle, but that was because I was throwin 3000 watts at 2 focall 11" woofers, but a little dynamat and that was all fixed! Otherwise, even with all the spl I am pushing it hasnt caused any issues with rattles anywhere else in my car.
