Brighter Bulbs
Old Jan 31, 2005 | 09:11 PM
Cal Jeff's Avatar
Cal Jeff
Default Brighter Bulbs
I put the Sylvania Silverstars in over the weekend. Yes they are much brighter. Does anyone know of a brighter yellow bulb or up grades for the fog lamps?
Old Jan 31, 2005 | 10:21 PM
chrisuscga01's Avatar
chrisuscga01
Default RE: Brighter Bulbs
Hey how hard was it to put the bulbs in? I heard the one side, not sure which, is a pain b/c you have to remove alot of stuff in the way.
Old Feb 1, 2005 | 08:46 AM
ramification's Avatar
ramification
It is an easy up-grade to do. From a 1-10 on the difficulty scale I would give it a 2. It is pretty easy to do and pretty hard to screw up. Take your time. Dont touch the bulb and everything will be as bright as day in no time.
Old Feb 1, 2005 | 04:23 PM
MattRobertson's Avatar
MattRobertson
I didn't have Cal Jeff's experience. Oh the builbs are easy to get to alright (you'll have to remove the airbox to get at the driver's side bulbs, which is easy) but they are a twist-unlock kind of mechanism, where at the end (or the beginning if removing) of the twist there is a solid detent that snaps the bulb into the housing.
I had no problem with the lo-beams for either side. But I had one heck of a time with the hi-beams as my hands were too big to fit well into the available space and I couldn't get the leverage needed to snap that bulb finally into place. Eventually I got it but I bet my girlfriend probably could have gotten a much better angle in there and just popped them in in a second.
No way was I asking her for help. Never would have heard the end of it.
Old Feb 1, 2005 | 06:49 PM
SRT MAGNUM's Avatar
SRT MAGNUM
Good Call
For brighter fogs or headlamps check out www.piaa.com. They are like 70 bucks a pair but are known for being EXCEPTIONAL
Old Feb 1, 2005 | 07:37 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
silverstar makes fog light bulbs....i have them in my RT...
Old Feb 2, 2005 | 01:54 PM
MikeEast's Avatar
MikeEast
Can someone post the part numbers?
Thanks!
Mike
Old Feb 2, 2005 | 02:00 PM
MagnumRT's Avatar
MagnumRT
I think that the stock bulbs do a good job as is, much better than the headlights on my old 96' Chevy Impala SS.
Much better!
Bob
Old Feb 2, 2005 | 02:51 PM
TxRide's Avatar
TxRide
Hi BadStrat, how hard was it to install? manual says " dealer serviced only", do you need any special tools?
greg
Old Feb 2, 2005 | 02:53 PM
TxRide's Avatar
TxRide
low beam- 9006
high beam- 9005
fog-H10/9145
