lower gearing for 1/4 mile
Old Apr 9, 2005 | 07:59 PM
maneval69's Avatar
maneval69
Default lower gearing for 1/4 mile
Food for thought.
Take the 17 inch wheels off the SE (if they fit) and mount 235-40 R17 wheels to run at the track.
With the stock wheels being 28.6 inches tall and the tire stated above being 24.4 inches tall, this change would be the same as changing from a 2.82 gear to a 3.30 rear gear.
What would that be worth in the 1/4? Assuming the change doesn't screw the transmission controls up.
Old Apr 10, 2005 | 03:12 PM
MagnumRT's Avatar
MagnumRT
Default RE: lower gearing for 1/4 mile
That is food for thought.......................................
Bob
Old Apr 11, 2005 | 04:21 AM
magnuman's Avatar
magnuman
Also don't have to buy Eibachs, because you get a free two inch lowering job with that tire. As long as you put all four on, I'll bet all you get is erronious speedometer readings. Ought to get us in the 13's and a little over 100 mph in the 1/4 mile with that setup.
Old Apr 11, 2005 | 12:50 PM
PropMan's Avatar
PropMan
Excpet for the fact that the 17" wheels will not clear the RT brakes!
Old Apr 18, 2005 | 08:32 AM
ink sindicate's Avatar
ink sindicate
get an xtra set of light 18's and put 0n some 255/30/18 and you will shave a few pounds of unsprung weight and come in at 24" even
Old Apr 27, 2005 | 12:07 AM
strippedhemi's Avatar
strippedhemi
Ive heard the V6s have a lower rear end gear ratio. Nothing to stop you from swapping it
