check light
Old Feb 26, 2010 | 12:56 PM
mballard34's Avatar
mballard34
Default check light
hello, i drive a Magnum 07, 3.5L. My check light is on and i checked it and got 0157 which is bank2 sensor2. I tried to clear the code by disconneting the battery for 30 min but the code came back as i start the car can yall tell me where this sensor would be located ??? the car has 91 000 kms about 36 000 miles, i am 2nd onwer got it at 82 000km i did not change the plug yet
can i switch both rear to see it it trows me another code of opposite sensor? the i know if the sensor is defective?
thanks
Mike
Old Feb 26, 2010 | 11:43 PM
master tech's Avatar
master tech
Site Moderator & Tech
Bank 2 is the right cylinder head or the passenger side, sensor 2 is the downsteam o2 sensor.
Old Feb 27, 2010 | 07:07 AM
mballard34's Avatar
mballard34
Thank you very much
What if i swap both rear sensor to see if the sensor is the real problem,
then i should get another code, being the driver side ?
Cause i dont have anything to test the sensor, and not much knowledge
regards
Michel
Old Dec 1, 2010 | 06:47 PM
mballard34's Avatar
mballard34
Great now after one year i get the 0137 code?
another sensor i guess, must be the other one ? passenger rear ?
Mike
