Oil Pan Drain Plug
Old May 11, 2005 | 09:51 PM
dodgemech's Avatar
dodgemech
Default RE: Oil Pan Drain Plug
ORIGINAL: MagnumSXT
Hadn't thought of that one. Does the dealership install a new plug at each oil change?
Some only replace them when the tech decide it's worn, our dealer changes every plug, every time.
Bob, I've had cars towed in for that. Usually they come in smoking and complain of lack of power.
Old May 11, 2005 | 11:26 PM
Rockadile's Avatar
Rockadile
ORIGINAL: dodgemech
ORIGINAL: Rockadile
I've been changing my own oil for the past 15 years and my wifes for the past 6 years. This is well over 10 cars and I've NEVER had to replace the drain plug. The Dodge doesn't look any different from the others. I always thought that it was something I'd have to pay attention to as I figured the built-in seal would wear over time, but I've never seen 1 leak. Maybe if it was overtightened, but since I did my own changes, I never had to worry about this. The fumuto valve looks interesting, though.
Well keep doing that way, I guess you can do your own work so you won't mind replacing an oil pan. Most folks would rather spend the extra 2.00 to replace the oil plug. Steel plugs in aluminum pans do not work very well, they have a nasty tendency to gall threads and as soon as the steel threads a sliver of Al in them they ruin the whole pan. Just my thoughts though.
Again, every car I've owned, I've changed my own oil. Never replaced the drain plug and I've never had any problems. I am not disputing what you are saying, but it seems to me that the problem is more the exception than the norm. Anyways, I always wipe the drain plug and the threads in the oil pan after draining. Maybe this has helped prevent the problems of which you speak.
Old May 12, 2005 | 12:07 PM
MagnumRT's Avatar
MagnumRT
Just remember that on the Hemi, the oil pan is aluminum and the drain plug is steel.
Did you other cars have an aluminum pan?
DodgeMech:
Do the V6 engines have the aluminum pan also on the Magnum? Or is it just the Hemi?
Bob
Old May 12, 2005 | 02:59 PM
Rockadile's Avatar
Rockadile
ORIGINAL: MagnumRT
I was just thinking about that. Never paid much attention, but I was thinking...I am not sure how replacing the drain plug whould make much difference if there are slivers of aluminum coming off the pan. If they were in the threads of the pan and you threaded a new plug in wouldn't it also do what DodgeMech is saying? I would think if the old plug looked good (and the threads were wiped out) and the pan threads were wiped out, this would prevent the problem as much (or better than) a new plug without doing this. Maybe I am missing something or oversimplifying (which I tend to do a lot).
Old May 12, 2005 | 10:20 PM
dodgemech's Avatar
dodgemech
The threads wear and the best prevention is a 2.00 plug with fresh clean threads. You also can't replace the oring seal by itself. It's just real cheap insurance against problems.
It's not all that uncommon either, I change about 4-5 pans a month.
Old May 13, 2005 | 08:27 PM
Rockadile's Avatar
Rockadile
ORIGINAL: dodgemech
Interesting. At $2 or so, it is not that big of a deal. Do you really think they need to replaced after every oil change? Or would every OTHER oil change be sufficient?
Old May 14, 2005 | 01:52 AM
dodgemech's Avatar
dodgemech
Ok, every other oil change is OK.
Old May 14, 2005 | 03:09 AM
2005 Magnum R/T Hemi's Avatar
Dodge Mech,
I am impressed that your dealership you work at replaces the plug. I was disappointed to read that my dealer only installed 6 quarts of oil in a car that takes 7. Let alone a new Oil Plug...
Old May 18, 2005 | 02:22 AM
MagnumSXT's Avatar
MagnumSXT
ORIGINAL: MagnumRT
DodgeMech:
Bob
Noone ever answered to I looked this evening while I was installing my foglights. The 3.5 does have an aluminum oil pan too.
Old May 18, 2005 | 06:19 PM
FlatEric's Avatar
FlatEric
My dealer put 7.5 LITERS in my RT that only takes 6.5 LITERS....figure that one out....
