Nitrous
I've got a nitrous question and I need a little advice. I've got a SXT with the 3.5L and I'm wanting to get a nitrous setup. Something small, maybe a 50-75 shot unit. Any ideas on kits available. Will I void my warranty? Installation costs? Reliability? Overall engine damage? I've done hundreds of bolt-ons to different vehicles but I've never used or installed nitrous. Any information that can be shared will be great.
i worked for a dealership...if they suspect that nitrous is the cause for an extreme engine problem, they evidently CAN find out. If you do install a system, dont put a trigger; make it self arming based on the throttle position sensor, and hide a switch somewhere inside where you wont bump it. i would always recommend a wet shot, because running a dry shot always increases your risk of running Too lean and burning something up. do you have mechanic knowledge? i raced/regularly drove a friend of mine's sebring last summer, and it had a Zex 55 shot...it made QUITE a difference...if you happen to find a system used, say from someone you know, make sure you check the date on the bottle...i know that they expire, but im not sure how long they are good for.
I was going to mount the bottle in the back with quick disconnects so that when I needed to put something in the back, all I would have to do is pull it out. A 50 shot would be perfect but I just can't stomach the thought of damaging the motor. On something like that, the dealer would nail you to the coufin. I guess I will just get my intake and Jet chip and see what that does for me.
i have seen a stratus RT with a jet box, and it was slower than my car without one...
Trending Topics
Ok well that pretty much does away with that idea. I ordered my intake today. I'll have it in about a week. I went with the Airraid unit with the MIT tube. We'll see how that does. There really aren't to many bolt-ons available right now for the Mag. I'll have to just wait patiently for stuff to drop.
ORIGINAL: Magman3
ORIGINAL: Magman3
Installation costs?
Installation costs?
ORIGINAL: Magman3
Reliability?
Reliability?
Should be vary reliable. I run 50 and 75 shots on 2.0 litre Neons all the time. I would not be afraid to run a 100 shot on a 3.5. The motor is strong enough to handle that.
ORIGINAL: Magman3
ORIGINAL: Magman3
