???for those w/rk hood
Old Jul 3, 2005 | 11:52 PM
65standard's Avatar
65standard
Default ???for those w/rk hood
what air intake system are you guys with the rksport viper hood using?
the 360 air intakez looks like the best design for this hood. with the lower holes in the box closed and a foam seal glued to the hood, i should have a closed ram-air system. i want to buy the 360 air intakez unless someone thinks there's a better one for a closed system.
Old Jul 4, 2005 | 01:02 PM
MagnumRT's Avatar
MagnumRT
Default RE: ???for those w/rk hood
Are you sure that you want an RK hood? I like the look of the hood also, but I hear that the quality is not there.
I was tempted to get one in the group buy, but glad I didn't.
Right now the shaker hood looks the best, but at $1,000 it is pricey.
Still waiting for something better to come out,
Bob
Old Jul 4, 2005 | 01:24 PM
65standard's Avatar
65standard
too late, i already have the rk hood. i am letting the hood cure for months so i don't have shrinking or warping problems after it's painted. i also filled the louvers to give me that smooth look i want.
if i had to do it over, i would buy the shaker hood. $1000 is a lot less than you would have in the rk hood.
rk hood $800 + shipping $160 + body/paint work $1325 + air intake system $200 == $2485
Old Jul 4, 2005 | 05:22 PM
magrt's Avatar
magrt
i used the airaid it seems to work real well and seals good. another idea for the hood , i cut the cheesey grate out and smothed the lower edge of the opening down and body worked it to flow into the hole. looks real clean and it dont have the expaned metal look. then we blacked the inside of the hole so we didnt have to run the stripes into it.
