UConnect Bluetooth Problem
Old Sep 6, 2011 | 08:44 AM
  #21
xsdbs's Avatar
xsdbs
Hmm, well that is quite strange. It tells you that the phone list is full but then it also tells you that there are no paired phones to delete. If you say, "setup, select phones" does it ask you for the name of the phone or tell you to say "list phones"? If say "list phones", does Uconnect name any phones?
Originally Posted by gatzby143
Sorry for the delay, I just got back from a business trip.
I went to Setup, phone pairing, delete phones, and it says there are no phones to delete, so I don't ever get that next option of all.
Old Sep 6, 2011 | 05:49 PM
  #22
gatzby143's Avatar
gatzby143
It asks me to list phones but when I do it says there are no phones paired.
Old Sep 7, 2011 | 02:37 PM
  #23
xsdbs's Avatar
xsdbs
well, I have covered all the basis that I can think of except for one. You tried the module from your other car, and it worked (if I remember correctly) and I'm pretty sure that if you tried the one that's wigging out in your other car that it still wouldn't work. Looks like you may want to call around a few bone yards to see if you can find a part. Sorry, I don't have anything else for you ton try. Weird that it would just stop working without any former issues.
Old Sep 7, 2011 | 08:27 PM
  #24
gatzby143's Avatar
gatzby143
I appreciate all your help. Thanks again. One more question though. Do you have a part name or part number I should ask for when calling around?
Old Sep 8, 2011 | 01:20 PM
  #25
xsdbs's Avatar
xsdbs
in the picture that you posted, there is a 05064013 #, use that PN or the # on the one in your other car. It may also be known as the hands free module. If you have a pick a part wrecking yard, you might just try calling and trying to find the approximate same year vehicle and pull it yourself to make sure it's the right module.
Old Sep 8, 2011 | 07:15 PM
  #26
gatzby143's Avatar
gatzby143
Thanks again for all your help. Members like you are what make car forums a wealth of information.
Old Sep 9, 2011 | 12:46 PM
  #27
xsdbs's Avatar
xsdbs
Thank you gatzby, I'm sorry I couldn't be more helpful with this issue. Good luck with finding a part.
Old Oct 17, 2011 | 09:30 PM
  #28
Dodgedan1's Avatar
Dodgedan1
Default Ucoonect issue with 2005 Magnum
New to this forum. I have a 2005 Magnum RT and am experiencing same problem with Uconnect. You tell the system to list or delete phones and it tells you there are none paired. When you try to pair a phone, it try's the fails indicating it cannot pair any more phones. Catch-22. I have pulled the radio fuse hoping to reset Uconnect but it didn't work. Thoughts?
Old Oct 18, 2011 | 05:28 PM
  #29
gatzby143's Avatar
gatzby143
I think your in the same boat as me and need to replace the telematics module located behind the glovebox.
Old Nov 27, 2011 | 08:18 PM
  #30
Dodgedan1's Avatar
Dodgedan1
Default UConnect Bluetooth Problem
I went to the Dodge dealer. They told me that they needed to use a STAR SCANNER unit to download new software updates to Uconnect. Unfortunately, this dealer did not have a Star Scanner. I am looking for a dealer in the Binghamton, NY area who has one. This sounds like the only option we all may have for fixing the PIA problem!
