engine temp
Old Oct 7, 2005 | 12:53 AM
widowmaker2's Avatar
widowmaker2
Default engine temp
Anyone ever put an actual number guage on the Magnum RT and see how hot it really runs. It seems like it is really hot...
Old Oct 7, 2005 | 03:51 PM
MagnumRT's Avatar
MagnumRT
Default RE: engine temp
Mine usually runs at 204 degrees, as high as 220 degress.
Bob
Old Oct 7, 2005 | 04:10 PM
widowmaker2
that seems awfully high...maybe not short term, but long term, that can not be good for the engine.
Did you put a real guage on there to find out the operating temp?
Old Oct 8, 2005 | 12:41 PM
MagnumRT's Avatar
MagnumRT
I have the factory package that allows me to change dash display and observe engine temp.
The Electronic Conv. package.
Remember that the coolant is under pressure, so the boiling point is higher than 212 degrees.
Yes, it is hot.............to lessen the engine emissions.
Bob
Old Oct 8, 2005 | 07:19 PM
65standard's Avatar
65standard
i changed my thermostat to a 180 and my car runs between 181-183 degrees when driving over 35mph. as high as 219 when in heavy traffic. the electric fans turn on low speed at 220 and high speed at 224. i need a programmer to adjust these settings. i want my fans to turn on low at 190 and high at 195. i don't want to see any higher that that.
if you ordered the optional electronic convenience group for $630, you will have the digital temperture gauge in the cluster.
Old Oct 11, 2005 | 01:12 AM
grinner's Avatar
grinner
where did you find that thermostat, 65?
I run around 220.
Old Oct 11, 2005 | 09:55 PM
65standard's Avatar
65standard
here are some part numbers for the 180 degree thermostat for the magnum.
stant #13078
napa #191
autozone #800-180
i bought mine at the napa auto parts store for $5.70
Old Oct 19, 2005 | 10:06 PM
2005 Magnum R/T Hemi's Avatar
Widow Maker 2,
I started an earlier thread addressing this issue. Seems the High Temperature is on Purpose. Hotter engines run more efficiently. Burns fuel better and all... Everyone else is getting the same results. About 219 or so for me... I like the Mirage Effect it puts off while you are sitting at a Red Light. (I like Red Lights!) You can see the heat in the shadow next to the car! One of the other Members told me, "I thought it was from the Fire Breathing Hemi under the Hood" lol
