Trans dipstick
Old Nov 4, 2005 | 06:35 PM
RT's Avatar
RT
Default Trans dipstick
Where can I purchase my own Transmission dipstick? I do all of my own maintenance and can't get myself to take my car into the dealer to have the fluis level checked.
2005 Magnum RT
Old Nov 4, 2005 | 10:29 PM
strippedhemi's Avatar
strippedhemi
Default RE: Trans dipstick
You might check parts department. But from what I gather, they dont want anyone messing with the tranny. If you have any problems down the road and they find like a different oil or additive, they may refuse warranty.
Old Nov 5, 2005 | 11:51 AM
MagnumRT's Avatar
MagnumRT
According to the dealer, you MUST bring the car to them to check your transmission fluid. It requires a special instrument (costs about $1,000) to properly check the fluid level. It isn't just the fluid level itself, it also factors in fluid temperature, etc.
I am with you, I would rather do my own maintenance, but they have us on this issue.
If I knew this up front, I would NOT have bought the car.
The car is great but too damn complicated.....................
Bob
Old Nov 7, 2005 | 11:26 AM
RT's Avatar
RT
Thanks for the replies. Sounds like someone is shipping a load of BULL! Last I checked a straightened coat hanger cost much less than $1000. I just have to know where to make the "full" mark. Unless I see a leak there shouldn't be any reason to check the level anyway. I'll keep looking.
Old Nov 7, 2005 | 06:57 PM
MagnumRT's Avatar
MagnumRT
You might try Warshawsky's auto parts catalog, they used to sell an adjustable dipstick.
Maybe some custom car accessory place..............LoCar?
You just need a dipstick with a sliding adjustable collar, should not be too hard to make one.
Bob
Old Nov 7, 2005 | 10:12 PM
RTracer's Avatar
RTracer
I believe the trannies on the RT are sealed. A dip stick wont do you anything. My brother is a tech at Mercedes...we have the same tranny as the e class, same story.
Old Nov 8, 2005 | 01:39 PM
MagnumRT's Avatar
MagnumRT
I think the tranny tube for the dipstick is not blocked, that is why they have a twist off plug on the top of the tranny tube. They have to have some way of inserting their test machine don't they?
Bob
Old Nov 9, 2005 | 04:21 PM
RIPSIGUY's Avatar
RIPSIGUY
A $1000.00 bucks for the tool? That is a load of S$%t.
Go to the dealer and ask to order special tool number 9336. It cant be more than fourty bucks. THe problem is the level has to be set according to the temp
of the tranny, it involves looking at trans temp with a scan tool.
Old Nov 19, 2005 | 03:01 AM
matmanc4's Avatar
matmanc4
the tool cost about 40 bucks and you can get it from the parts dept. Its readily available had to buy a replacement the other day.
Old Nov 20, 2005 | 01:33 AM
tenntech's Avatar
tenntech
The dealer tool does not have a full and add mark, it has several marks and is adjusted by reading the trans temp at the time of filling. The dipstick is not to costly but you still have to know trans temp.
