starting issues magnum 2005
Old Feb 5, 2018 | 04:16 AM
vertn's Avatar
vertn
Default starting issues magnum 2005
2005 magnum 6 cylinder 249000.
Old Feb 5, 2018 | 04:18 AM
vertn's Avatar
vertn
Magnum 2005 6 cylinder 3.5. I am having starting issues sometimes it starts with no problems. And there are times that I need to jump it 3 times in a row it can be after driving 40 miles or after driving3 miles. it will try to start like the battery is dead and then start clicking. sometimes after I try it 3 or 4 times it will start. if not I jump it and no problem. everything works lights radio etc. It just recently started this with some constant issues. I have had to jump it 3 times before within this pass year. But I was tailgating and just figured it was we had the doors open and the radio on. Also 3 or 4 times in the last 4 or 5 years it shut off while driving. I put a new battery in it and same issue. When I first put the battery in there was new issues slow starts or any other problems and its been about 3 weeks and this problem comes back. Any advice on where to start to look for the problem? I did try the alternator home check taking the cable off and the car kept running. Thanks again for any help
Old Feb 5, 2018 | 09:17 AM
have the starter tested. Local parts store might be able to do it for you. If it's original, probably time for replacement.
Old Feb 5, 2018 | 01:10 PM
HemiLonestar's Avatar
HemiLonestar
Starter tested, battery tested and see if you have any dirty connections to the starter and/or voltage drop from the battery to the front of the car.
