05 r/t codes p0032,p0038,p0052,p0058 dying and throttle issues after warm up
Old 07-10-2018, 07:53 PM
Mark05r/t's Avatar
Mark05r/t
Mark05r/t is offline
Default 05 r/t codes p0032,p0038,p0052,p0058 dying and throttle issues after warm up
I have an 05 magnum r/t awd with 113,000 miles that has been dying when the car gets hot. The check engine light is on and is throwing p0032,p0038,p0052,p0058 which says oxygen sensors. Before the car dies it starts idling very rough and sometimes the throttle engages and revs up without me touching the pedal. I wouldn't think all oxygen sensors would go bad at the same time nor would it be making the engine do that. I don't have a lot of mechanical knowledge and have not been able to find anything while researching this same issue. Any feedback would be appreciated, thanks.
Old 03-26-2019, 03:17 PM
jtrides65's Avatar
jtrides65
jtrides65 is offline
Default My 06 magnum rt doe the same thing
Did you ever find out why all the codes said o2 sensors bad?
Old 06-03-2019, 12:06 AM
Mark05r/t's Avatar
Mark05r/t
I did not. The issue only occurs when it is 85+ degrees outside so 9 months out of the year it runs fine
Quick Reply: 05 r/t codes p0032,p0038,p0052,p0058 dying and throttle issues after warm up
