Stupid question, can't do a burnout
Old Apr 4, 2020 | 11:47 PM
Vontae Burleson's Avatar
Vontae Burleson
Default Stupid question, can't do a burnout
I’m going to sound stupid but I have a dodge magnum 2.1L v6 and it refuses to burn out any help?
Old Apr 5, 2020 | 07:52 AM
Traction control?
Heavy car, small motor. Not really a surprise.
Old Apr 6, 2020 | 12:02 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
It's a 190hp/190 ft/lbs 2.7L V6 and you're honestly wondering why it can't break the tires loose on a 4100+lb wagon...?
Old Apr 6, 2020 | 02:22 PM
Shoulda bought a V8.....
Old Apr 22, 2020 | 05:29 PM
Garncarz's Avatar
Garncarz
Put her in nootch.
Advance the accelerator until your tach reads 7,000+ rpm.
Keep your foot down and count to 10.
Don't cheat and go early (it's a flywheel inertia thing)!!
Gently pull the shifter back into "D".
Bob's your uncle.
Old Apr 22, 2020 | 05:36 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Originally Posted by Garncarz
Put her in nootch.
Advance the accelerator until your tach reads 7000+.
Keep your foot down!
Pull the shifter back into "D".
Bob's your uncle.
Definitely won't do any after that LMAO...42RLE everywhere
Old Apr 22, 2020 | 05:38 PM
Garncarz's Avatar
Garncarz
The OP said the wanted to burn out. Do you think he meant tires?
Old Apr 22, 2020 | 05:39 PM
ol' grouch's Avatar
ol' grouch
If you're planning to replace the tires soon and the paint is just okay, not show quality, wipe some brake fluid on the tires with a rag. You'll light them right up. Be sure to get all the brake fluid off the body afterward and don't go around any corners afterward. The hard part will be to keep them planted later.
If this is your daily driver to get towork, find something else to play with and not ruin your car.
Old Apr 22, 2020 | 05:42 PM
Garncarz's Avatar
Garncarz
A 7000 rpm launch AND brake fluid soaked tires, now there's a recipe!!
Old Apr 22, 2020 | 06:15 PM
ol' grouch's Avatar
ol' grouch
In high school, I watched s guy do that with the bias ply tires of the time. Very impressive right off idle. When the police showed up, we all got away but him. Every time he's try to speed up, burn out city. I'd say 900-1000 rpm should suffice for brake fluid wiped tires.
