SRT-10 rims fit??
Old Aug 1, 2004 | 09:46 PM
Hemi RT's Avatar
Hemi RT
Default SRT-10 rims fit??
Does anyone know if the SRT-10 rims will fit on the RT? The rims from the truck not the viper.
Old Aug 2, 2004 | 01:27 AM
blackmagnumrt's Avatar
blackmagnumrt
Default RE: SRT-10 rims fit??
The bolt pattern appears to be the same but I think you would be limited by the width of the SRT-10 rim (10"). I believe the widest you could get onto the Magnum is 8.5". There have been quite a few rim swaps among regular posters to this forum. Anyone gone wider than 8.5"?
Nick
Old Aug 3, 2004 | 01:51 AM
sikpuppy's Avatar
sikpuppy
To go wider than 8.5", you will have to go up in diameter. I went to a 9" x 20" to get the extra width but you may just have to go to a 19" if you can find them in the proper bolt pattern. I believe I saw someone in DF that had 18 x 8.5 on front and 19 x 10 on rear but I can't remember where or who. If I come across the post again I'll let you know
Old Aug 3, 2004 | 03:31 PM
shiltz's Avatar
shiltz
sikpuppy, with the rims you have do you know if the extra 1.5" over the stock is spaced evenly (1/2 inward, 1/2 outward) or is it more biased or entirely to one or the other, just wondering cause I want to replace the factory tires but I want to keep the factory rims cause I don't like the look of any of the aftermarket rims i've seen and since no one else makes 225/60-18 I was thinking of going with 245/55-18 which is the same OD as stock or 255/55-18 which is .4" larger OD but I was wondering if I would have any rubbing issues due to the extra width of the tires.
Old Aug 3, 2004 | 03:40 PM
blackmagnumrt
I am running BF Goodrich G-Force T/A KDWS at 245/55-18. They are a direct fit for factory wheels. I have been extremely pleased with them so far (about 800 miles on them). Finally, no hydroplaning! The 245/55-18 and the 225/60-18 are the only direct fit sizes that will allow you to keep an adequate load rating for your tires. The best thing about the BFG's? Around $85 per tire from the Tire Rack.
Nick
Old Aug 3, 2004 | 04:37 PM
shiltz's Avatar
shiltz
thanks Nick, those are actualy one of the two tires I was looking at, only reason I was looking at the 255/55-18 as well is because of the lack of options in 245/55-18, those BF Goodrich ones were the only ones I could find and I wanted to go with a grippier summer tire and just swap the factory tires on for the winter, for the 255/55-18 I was looking at the BFGoodrich g-Force T/A KDW-2 which are a very grippy summer tire and I figured the extra 0.4" OD wouldn't be an issue. how are the BF Goodrich G-Force T/A KDWS as far as dry weather traction compared to the stock continentals?
Old Aug 3, 2004 | 04:40 PM
blackmagnumrt
They are working great. Much more stick than the stock tires (wet and dry). No hydroplaning even in heavy rain. Corners like a dream. Ride is very nice. Just a tad more road feel but nothing of any concern. I read all of the comments at Tire Rack and some were quite negative. I'm glad I took the chance and wound up with a real performance tire that has some all season use at a bargain price.
Nick
