Dodge Muscle Cars When it was all about noise and big (and bigger) engines, Dodge and Plymouth ruled the roads. Discuss the Muscle cars that once were within.
March pulleys
Old Feb 9, 2005 | 01:35 PM
moparturd's Avatar
moparturd
Default March pulleys
Anyone have any experience with the march pulleys. I'm going to be going to manual steering and want to switch to new pulleys for the water pump and alternator.
Old Feb 9, 2005 | 07:19 PM
fc7gtx's Avatar
fc7gtx
Default RE: March pulleys
Can't say I have but if you ever want to keep the OEM pulley's you might call one of these guys.
Pulley's
As these guys:
Pulley's #2
Chris
Old Feb 10, 2005 | 11:32 AM
moparturd's Avatar
moparturd
Thanks.
Old Feb 11, 2005 | 11:03 AM
71RoadRunner's Avatar
71RoadRunner
They are very nice, my dad has them on his '69 Charger and they look great as well as perform, but they were put on as part of the engine build up so I cannot say what kind of gains they give. Here is a picture showing them all (he also converter to the serpentine belt):
[IMG]local://upfiles/193/E52FE786C78841B0ABB39C818241916D.jpg[/IMG]
Old Feb 13, 2005 | 01:17 PM
big asp's Avatar
big asp
Double check sizes for your specific application. You can't just buy a kit for a small block and have it fit. I had to wait on pulleys for several lllllooooooooonnnnnnnnggggg days to fire up a Magnum 380 crate engine in my old Barracuda because of different water pump clearances.
Old Feb 25, 2005 | 11:02 PM
rumblefish360's Avatar
rumblefish360
Todd;
I have a set on my old school 360. They fit very tight and are a pain to set up. (a little bit I should say.) The surplied bolts for the alt. and P/S where short. I had to go back and forth with them twice till it was settled. Most people that I have read posts from have ill things to say about them. My exp. was OK. I used the serpintine system.
Old Mar 2, 2005 | 10:22 PM
moparturd's Avatar
moparturd
That's the route I want to go. Use the serpintine belt so there are fewer chances of throwing belts.
Old Mar 7, 2005 | 12:30 AM
rumblefish360
Thats one reason I did it that way.
