Dodge Muscle Cars When it was all about noise and big (and bigger) engines, Dodge and Plymouth ruled the roads. Discuss the Muscle cars that once were within.
what size thermostat
Old Jun 20, 2005 | 09:22 PM
skoozie4406pk's Avatar
skoozie4406pk
Default what size thermostat
i've got a 440 6 pack car what size thermostat do i put in there.
i see mopar performance has a 180 degree for about 7 bucks????
or should i put in a 160 degree one??
Old Jun 21, 2005 | 01:04 AM
fc7gtx's Avatar
fc7gtx
Default RE: what size thermostat
With a good cooling sytem the 180 would be the best bet. I run the 180 and have always had good temps both cruisin and in stop n go traffic.
Chris
Old Jun 22, 2005 | 07:08 PM
big asp's Avatar
big asp
I also use the 180 thermostat and even without a shroud I stay cool in stop and go traffic. I do have a huge custom core in my radiator.
Old Jul 30, 2005 | 02:35 PM
RedSS454's Avatar
RedSS454
I have always heard run 10-20 degree cooler T-stat then you want to run. THis can cause a problem if you drive a lot in the winter, as it will take a long time to warm up, but I have never been over 185 since going tot he 160 stat.
Chris
Old Jul 30, 2005 | 04:02 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
i run NO thermostat, as my car does not see winter, and the cooler, the better for me.
Old Nov 21, 2005 | 12:25 AM
stormer426's Avatar
stormer426
I have had luck with using a restrictor ring only, easy way is to gut your thermostat poppet type (balance sleeve design to big) temps good year round in this area So.Ca. 28-115 degrees ambeint, and no innerds left to ever cause problems, most RB's want 1 1/2" or so LA's seem to like 1" drag race car LA uses .875 and runs 190 or so @ stage 215-220 at timing shack 200 or so on return road. If you've nothing better to do you may spend some time with various sizes untill you have your own idea of temp.perfection! It took 3 times to get my V-10 Ram3500 to where it's a happy medium.
