Dodge Muscle Cars When it was all about noise and big (and bigger) engines, Dodge and Plymouth ruled the roads. Discuss the Muscle cars that once were within.
clutch fan
Old Aug 25, 2004 | 10:26 PM
skoozie4406pk's Avatar
skoozie4406pk
Default clutch fan
i am thinking of buying a Mopar Performance Viscous Fan Package
for my 440-6pack. i currently just have a stock 4 blade solid shaft fan, no shroud.
will me buying this 5 blade clutch fan improve my cooling(expecially at low speeds), and also will i gain horse power? please please help!
Old Aug 27, 2004 | 02:32 PM
71RoadRunner's Avatar
71RoadRunner
Default RE: clutch fan
It will improve the cooling, but a fan shroud would possibly be even more benefitial to you. It will also free up lost horsepower that your current fan is robbing you of, as well as allowing the engine to rev up quicker.
Old Aug 30, 2004 | 06:23 PM
skoozie4406pk
thanks for your input
Old Jan 30, 2005 | 12:07 AM
fc7gtx's Avatar
fc7gtx
A fan shroud would be the next item I would buy along with a factory 7 blade fan. They came factory with these big blocks. I have no problem cooling with that package.....[sm=smiley20.gif]
Old Feb 25, 2005 | 11:05 PM
rumblefish360's Avatar
rumblefish360
In MoPar Muscule, Dulich did a test, but not with the 7 blade fan. The Viscous fan made 15 more HP than it's nearest rival. Use with shroud for max bennifit.
Old Feb 26, 2005 | 09:15 AM
71RoadRunner
Yep. I had a super lightweight Flex-A-Lite aluminum flex fan on my Roadrunner, until one of the blades broke off, thankfully it did no damage since it came loose while it was idling in a parking lot at the time. After removal I found that a couple other blades were cracked and ready to break loose as well. I highly suggest that no one ever under any circumstances use a flex fan unless it is one of the one piece plastic fans. I highly recommend the use of the Mopar Performance viscious fan package, I switched to it and it's doing a great job.
