questions???
Old Sep 24, 2004 | 01:52 PM
newtoneon's Avatar
newtoneon
Default RE: questions???
sorry casper im totaly lost, so what is the name of the product at modernperformanceproduct? thanks
Old Sep 25, 2004 | 05:53 AM
NeoAngelo's Avatar
NeoAngelo
If you go there and click on 95-99 neons. Goto engine and transmission. If you look near the bottom (or hit ctrl+f and type in cam) you'll eventually come to crane cams. Click the info, the top numbers are for SOHC, bottom for DOHC. The #12's are the second one on the list, the one listed for nitrous use, can be used either way. Everyone I know swears by the 12's.
Old Sep 26, 2004 | 04:31 AM
casper's Avatar
casper
Crane cams #10, 12, and 14.
Old Sep 27, 2004 | 02:21 PM
Altima_wb's Avatar
Altima_wb
#10 camshaft id slightly better then stock and will make a differenc but not a lot. Crane #12 is the best one for the average neon tuner gives great power and you don't lose much low end at all plus you start to get a bit of a cool idle . Crane #14 works great with NO2 and high compression full NA build, needless to say not really recommend for the street but damn does the idle sound cool.
Old Sep 28, 2004 | 03:40 AM
casper's Avatar
casper
yeah i'm going with the 14, only cause I have a 50/50 that i'm gonna go turbo. I figure that if I don't I only need low end in one gear 1st, and most of my driving is above 15mph.
Old Sep 28, 2004 | 12:49 PM
newtoneon's Avatar
newtoneon
thanks for all the info guys now i know what im looking for.
