Replacing Automatic window motor
Old Sep 24, 2004 | 08:18 PM
rs97ap's Avatar
rs97ap
Default Replacing Automatic window motor
Hi,
Mine is a 97 neon with power windows only on 2 front doors. Switches started to act up and the funniest thing is - I couldn't find 2 similar switches in whole Toronto. I am thinking of replacing the power windows with manual window cranks.
Can anyone confirm if it is just a matter of removing the motors and put manual cranks? Or are there any other complications?
Thanks guys...
Old Sep 26, 2004 | 04:35 AM
casper's Avatar
casper
Default RE: Replacing Automatic window motor
you can get them on ebay or at a junk yard. To change to manual, you will have to change the whole mechanism, as well as the door panels.
Old Sep 26, 2004 | 01:07 PM
sushi423's Avatar
sushi423
is it hard to just fix an automatic window? i believe my motor is dieing....it goes up WAYY to slow then sometimes it stops way short...it isnt helping on the eway and when it rains either i was thinking of fixing it myself or at least opening the door panels and taking a look.
Old Sep 26, 2004 | 10:58 PM
casper's Avatar
casper
should be able to pick one up from a junk yard $50-$75, or new about $150. Its not that bad to take the door panels off, but it is a tight space to work in and is a little of a PITA. But its not that bad maybe 1-2hrs.
Old Sep 27, 2004 | 12:29 PM
rs97ap's Avatar
rs97ap
Well, actually it's not that difficult to fix. The motor is working just fine - just the switches are not working. So far I looked into a few junk-yards, Canadian Tire - no one seems to carry power window switch (surprise, surprise)... I will check ebay though.
I don't need the whole mechanism, only the swith... Any other suggestions on places that might carry different model switches???
Old Sep 27, 2004 | 12:43 PM
Altima_wb's Avatar
Altima_wb
Wait a minute you only have power windows on the front 2 doors and none on the back? Sounds like you might have aftermarket power windows.
Old Sep 27, 2004 | 12:56 PM
rs97ap's Avatar
rs97ap
Yup, it was put by the previous owner. And they didn't do a very good job - I can tell you that...
Old Sep 27, 2004 | 01:12 PM
Altima_wb's Avatar
Altima_wb
Your going to have to find a switch from the company that made the kit or just make a switch fit.
Old Sep 27, 2004 | 08:55 PM
sushi423's Avatar
sushi423
uh all first gen neons have power windows in teh front and manuals in the back that dont go down very far..or so i thought....when i say all i mean neons with power windows.
Old Sep 27, 2004 | 09:37 PM
LowSlowNeon's Avatar
LowSlowNeon
Mine is like that to, power in the front, manual in back. I don't remember if there was an option for power windows all around. The reason the windows don't go all the way down in the back is there physically isn't enough room for them to go all the way down.
